Fuchs Center Caps, Wrong size |
warrenoliver |
Aug 25 2007, 04:13 PM
Member Group: Members Posts: 363 Joined: 11-November 06 From: McFarland, Wisconsin Member No.: 7,199 Region Association: Upper MidWest |
How do I tell what size Fuchs centers fit on my 15" Fuchs? I have a set of 5 bolt Fuchs that I was told takes the "early 3 prong cap". Well, I bought one off evilbay (good thing I didn't buy all 4), and it is too small (IMG:style_emoticons/default/chair.gif)
The wheel hole is 2 3/4" and the cap I have is about 2 1/2". Which ones fit on these wheels? BTW anyone interested in a single Fuchs center cap for what I put into it? Warrenoliver. |
smg914 |
Aug 25 2007, 04:22 PM
Sahara Beige Steve Group: Members Posts: 1,962 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 Region Association: None |
Verify the part number on the back of your wheels and compare it to this. Sounds like your wheels use the ring type center cap.
901.361.012.03 6X15 36mm offset, (3-prong center cap) 901.361.012.06 6X15 36mm offset, (3 prong center cap) 911.361.020.00 6X15 36mm, ‘72-‘73 (3-prong center cap) 911.361.020.10 6X15 36mm, ‘74-‘77 (ring type center cap) |
warrenoliver |
Aug 25 2007, 04:29 PM
Verify the part number on the back of your wheels and compare it to this. Sounds like your wheels use the ring type center cap. 901.361.012.03 6X15 36mm offset, (3-prong center cap) 901.361.012.06 6X15 36mm offset, (3 prong center cap) 911.361.020.00 6X15 36mm, ‘72-‘73 (3-prong center cap) 911.361.020.10 6X15 36mm, ‘74-‘77 (ring type center cap) (IMG:style_emoticons/default/aktion035.gif) Wow! Thanks for the info. Now where in the world did you get that info? I have searched for that kind of info, and all along you had it (IMG:style_emoticons/default/thumb3d.gif) Any good ideas on where to get the caps (reasonable) once I find the numbers? Warrenoliver |
smg914 |
Aug 25 2007, 06:03 PM
It took me quite a bit of time to compile all this data but I thought I would do my good deed of the day and pass it on to everyone here on the web site. I realize there is one discrepancy with part # 911.361.020.42. The rear 8X15 Fuchs on my M471 GT are part # 911.361.020.42 but somewhere along the way I was told that this same part number was on someone’s 7X15 Fuchs but I really thing this is wrong.
901.361.016.00 5.5X14 46mm offset, 67-71 911 T/E & 914-6 911.361.016.10 5.5X14 46mm offset, 67-71 911 T/E & 914-6 901.361.012.01 4.5X15 42mm offset, ‘67 911S 901.361.012.04 5.5X15 42mm offset, ‘68 911S 901.361.017.00 5.5X15 (MAHLE, 9.9 lbs.) ‘70-‘71 911T & 914-6 901.361.012.03 6X15 36mm offset, early 6R wheel 901.361.012.06 6X15 36mm offset, ’69-’71 early deep dish 911.361.020.00 6X15 36mm, ‘72-‘73 (3-prong center cap) 911.361.020.10 6X15 36mm, ‘74-‘77 (ring type center cap) 901.361.012.05 7X15 49mm offset, deep dish, 911R 911.361.020.01 7X15 23.3mm offset (2.7RS)(3 prong center cap) 911.361.020.11 7X15 23.3mm offset (73-77carrera)(ring type cap) 911.361.020.41 7X15 23.3mm offset (911SC) 911.361.020.42 7X15 23.3mm offset 911.361.020.02 8X15 10.6mm offset 911.361.020.12 8X15 10.6mm offset (ring type cap) 911.361.020.42 8X15 10.6mm offset 911.361.020.03 9X15 3.0mm offset 911.361.020.06 9X15 3.0mm offset 911.361.020.05 11X15 46mm offset, 911RSR |
SGB |
Aug 25 2007, 09:04 PM
FABULOUS! Thanks very much Steve. This really needs to go into the "914 info" section- in technical information... I guess "Body Dimensions". I'm going to suggest you post it in there, or we may have to get someone to do it, IDK...
Anyway, thanks for the effort and for sharing. |
Lightweight_911 |
Aug 26 2007, 07:53 AM
Member Group: Members Posts: 71 Joined: 7-October 06 From: London, UK Member No.: 7,008 |
smg914 - you're correct - 911.361.020.42 was the later 8x15" Fuchs wheel & that part number did not apply to the 7x15" version.
Also you might want to add the fact that 911.361.020.02 - the early 8x15" Fuchs that was fitted to the rear of the RS after Mar '73 - accepts the 3-pronged centre caps. I have never seen (or heard of) a 9x15" Fuchs with the '06' part number - where did you get this info from ? |
smg914 |
Aug 27 2007, 03:18 PM
Thanks for the information Andy. Probably for the last 8 to 10 years I kept a 15" FUCHS WHEELS draft in my email folder and added parts numbers and info everytime I would see a part number on the web (ebay, rennslist, early 911 registry, pelican, etc) I would add it to my list. Obviously somewhere along the way I saw the data on someones 9X15 inch wheel.
Lo-Fi Version | Time is now: 10th May 2024 - 12:14 PM |
