warrenoliver
Aug 25 2007, 04:13 PM
How do I tell what size Fuchs centers fit on my 15" Fuchs? I have a set of 5 bolt Fuchs that I was told takes the "early 3 prong cap". Well, I bought one off evilbay (good thing I didn't buy all 4), and it is too small
The wheel hole is 2 3/4" and the cap I have is about 2 1/2". Which ones fit on these wheels?
BTW anyone interested in a single Fuchs center cap for what I put into it?
Warrenoliver.
smg914
Aug 25 2007, 04:22 PM
Verify the part number on the back of your wheels and compare it to this. Sounds like your wheels use the ring type center cap.
901.361.012.03 6X15 36mm offset, (3-prong center cap)
901.361.012.06 6X15 36mm offset, (3 prong center cap)
911.361.020.00 6X15 36mm, ‘72-‘73 (3-prong center cap)
911.361.020.10 6X15 36mm, ‘74-‘77 (ring type center cap)
warrenoliver
Aug 25 2007, 04:29 PM
QUOTE(smg914 @ Aug 25 2007, 05:22 PM)
Wow! Thanks for the info. Now where in the world did you get that info? I have searched for that kind of info, and all along you had it
Any good ideas on where to get the caps (reasonable) once I find the numbers?
Warrenoliver
smg914
Aug 25 2007, 06:03 PM
It took me quite a bit of time to compile all this data but I thought I would do my good deed of the day and pass it on to everyone here on the web site. I realize there is one discrepancy with part # 911.361.020.42. The rear 8X15 Fuchs on my M471 GT are part # 911.361.020.42 but somewhere along the way I was told that this same part number was on someone’s 7X15 Fuchs but I really thing this is wrong.
901.361.016.00 5.5X14 46mm offset, 67-71 911 T/E & 914-6
911.361.016.10 5.5X14 46mm offset, 67-71 911 T/E & 914-6
901.361.012.01 4.5X15 42mm offset, ‘67 911S
901.361.012.04 5.5X15 42mm offset, ‘68 911S
901.361.017.00 5.5X15 (MAHLE, 9.9 lbs.) ‘70-‘71 911T & 914-6
901.361.012.03 6X15 36mm offset, early 6R wheel
901.361.012.06 6X15 36mm offset, ’69-’71 early deep dish
901.361.012.05 7X15 49mm offset, deep dish, 911R
911.361.020.01 7X15 23.3mm offset (2.7RS)(3 prong center cap)
911.361.020.11 7X15 23.3mm offset (73-77carrera)(ring type cap)
911.361.020.41 7X15 23.3mm offset (911SC)
911.361.020.42 7X15 23.3mm offset
911.361.020.02 8X15 10.6mm offset
911.361.020.12 8X15 10.6mm offset (ring type cap)
911.361.020.42 8X15 10.6mm offset
911.361.020.03 9X15 3.0mm offset
911.361.020.06 9X15 3.0mm offset
911.361.020.05 11X15 46mm offset, 911RSR
SGB
Aug 25 2007, 09:04 PM
FABULOUS! Thanks very much Steve. This really needs to go into the "914 info" section- in technical information... I guess "Body Dimensions". I'm going to suggest you post it in there, or we may have to get someone to do it, IDK...
Anyway, thanks for the effort and for sharing.
Lightweight_911
Aug 26 2007, 07:53 AM
smg914 - you're correct - 911.361.020.42 was the later 8x15" Fuchs wheel & that part number did not apply to the 7x15" version.
Also you might want to add the fact that 911.361.020.02 - the early 8x15" Fuchs that was fitted to the rear of the RS after Mar '73 - accepts the 3-pronged centre caps.
I have never seen (or heard of) a 9x15" Fuchs with the '06' part number - where did you get this info from ?
smg914
Aug 27 2007, 03:18 PM
Thanks for the information Andy. Probably for the last 8 to 10 years I kept a 15" FUCHS WHEELS draft in my email folder and added parts numbers and info everytime I would see a part number on the web (ebay, rennslist, early 911 registry, pelican, etc) I would add it to my list. Obviously somewhere along the way I saw the data on someones 9X15 inch wheel.
