Paint Overspray |
Paint Overspray |
por73914 |
Aug 28 2007, 10:44 AM
I don't know what the hell I am doing... Group: Members Posts: 349 Joined: 10-April 07 From: Fayetteville, AR Member No.: 7,660 |
Is there a way to get paint overspray off of chrome and lenses? (IMG:style_emoticons/default/confused24.gif)
URY914 |
Aug 28 2007, 10:54 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,578 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Rubbing or polishing compound and elbow grease.
Chrome and glass will be easy. Plastic lenses you need to by VERY carefull. |
So.Cal.914 |
Aug 28 2007, 10:58 AM
Rubbing or polishing compound and elbow grease. Chrome and glass will be easy. Plastic lenses you need to by VERY carefull. (IMG:style_emoticons/default/agree.gif) Though you can use 'Goof off' on the chrome and glass, not plastic. |
por73914 |
Aug 28 2007, 11:03 AM
Thanks Guy, I think I will buying all new lenses. I bought a 72 Charger from a guy that painted it black along with all the lenses and some of the chrome...You know how expensive masking tape can be? (IMG:style_emoticons/default/WTF.gif)
markb |
Aug 28 2007, 11:22 AM
If you soak the stuff in Simple Green for awhile the paint will come right off. I'm told you're not supposed to use it on aluminum, though.
por73914 |
Aug 28 2007, 11:46 AM
If you soak the stuff in Simple Green for awhile the paint will come right off. I'm told you're not supposed to use it on aluminum, though. I will give that a shot tonight...I have already accepted that I was going to buy lense so if it hurts them no big deal. Thanks for the tip! (IMG:style_emoticons/default/beerchug.gif) |
SGB |
Aug 28 2007, 06:41 PM
Please let us know if it works.
914rrr |
Aug 28 2007, 07:52 PM
Senior Member Group: Members Posts: 1,830 Joined: 1-July 03 From: Knoxville, TN Member No.: 874 Region Association: South East States |
If you soak the stuff in Simple Green for awhile the paint will come right off. I'm told you're not supposed to use it on aluminum, though. I will give that a shot tonight...I have already accepted that I was going to buy lense so if it hurts them no big deal. Thanks for the tip! (IMG:style_emoticons/default/beerchug.gif) Before you buy new lenses, you might try Novus plastic polish. Comes in 3 different 'grits'. Works wonders on removing DAPO mistakes like overspray from lenses. |
orthobiz |
Aug 28 2007, 08:06 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
I read you can use clay to take overspray off.
Paul |
IronHillRestorations |
Aug 28 2007, 08:13 PM
I. I. R. C. Group: Members Posts: 6,717 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Laquer thinner will probably take off the paint.
HoppHead |
Aug 29 2007, 02:31 AM
Newbie Group: Members Posts: 1 Joined: 6-May 07 From: North Carolina USA Member No.: 7,718 |
IMHO I think a clay bar works better, is gentler on the paint and less messy. One can always go a bit more aggressive if needed.
HH |
por73914 |
Aug 29 2007, 06:55 AM
Please let us know if it works. I let a lense soak overnight in Simple Green and it did not work for me. Also I might add the chrome has some over spray but the lenses were just painted over. (IMG:style_emoticons/default/WTF.gif) |
tdgray |
Aug 29 2007, 07:04 AM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
Go to your local flaps and get a clay bar and the solvent they sell with it.
Works damn good |
markb |
Aug 29 2007, 11:46 AM
Please let us know if it works. I let a lense soak overnight in Simple Green and it did not work for me. Also I might add the chrome has some over spray but the lenses were just painted over. (IMG:style_emoticons/default/WTF.gif) You might need to leave it longer than overnight. I soak old cruddy foglight surrounds for a while (week?), and the stuff washes right off. |
Lo-Fi Version | Time is now: 14th May 2024 - 09:08 PM |
