1970 rear trunk, how do i open it? |
jocur43 |
Aug 30 2007, 05:58 PM
Newbie Group: Members Posts: 2 Joined: 30-August 07 From: florida Member No.: 8,056 |
how do i open the trunk on a 1970 914?
1970 Neun vierzehn |
Aug 30 2007, 06:14 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
J,
First (IMG:style_emoticons/default/welcome.png) Second, I'm assuming you don't have an(aftermarket) rear panel installed between the tail lights. The center button between the two tail lights is pushed in to unlatch the trunk. A valet key or a "master" key, turned 90 degrees in the push button locks/unlocks the rear trunk. Hopefully your key(s) work in that lock. Paul |
Aug 30 2007, 06:18 PM
If it's the front trunk that you can't open, the small "T" shaped handle beneath the left side of the dash is pulled to release the latch on the front trunk. That handle also locks in a similar fashion as the rear trunk button with a key.
jocur43 |
Aug 31 2007, 10:05 AM
J, First (IMG:style_emoticons/default/welcome.png) Second, I'm assuming you don't have an(aftermarket) rear panel installed between the tail lights. The center button between the two tail lights is pushed in to unlatch the trunk. A valet key or a "master" key, turned 90 degrees in the push button locks/unlocks the rear trunk. Hopefully your key(s) work in that lock. Paul I'm afraid it does have the rear panel. Any ideas? Thanks |
davep |
Aug 31 2007, 11:11 AM
914 Historian Group: Benefactors Posts: 5,138 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
There were two common methods of release. An electric solenoid operated by a switch somewhere. A pull knob cable release usually located near the engine lid release beside the drivers door.
What VIN is your car? |
Pat Garvey |
Sep 20 2007, 09:40 PM
Were you ever able to get the trunk open?
And, we need your VIN for posterity. It's on a plate (small), on the drivers' side windshield post. Let us know Pat |
Lo-Fi Version | Time is now: 8th May 2024 - 02:52 AM |
