jocur43
Aug 30 2007, 05:58 PM
how do i open the trunk on a 1970 914?
1970 Neun vierzehn
Aug 30 2007, 06:14 PM
J,
First
Second, I'm assuming you don't have an(aftermarket) rear panel installed between the tail lights. The center button between the two tail lights is pushed in to unlatch the trunk. A valet key or a "master" key, turned 90 degrees in the push button locks/unlocks the rear trunk. Hopefully your key(s) work in that lock.
Paul
1970 Neun vierzehn
Aug 30 2007, 06:18 PM
If it's the front trunk that you can't open, the small "T" shaped handle beneath the left side of the dash is pulled to release the latch on the front trunk. That handle also locks in a similar fashion as the rear trunk button with a key.
jocur43
Aug 31 2007, 10:05 AM
QUOTE(1970 Neun vierzehn @ Aug 30 2007, 04:14 PM)
J,
First
Paul
I'm afraid it does have the rear panel. Any ideas? Thanks
davep
Aug 31 2007, 11:11 AM
There were two common methods of release. An electric solenoid operated by a switch somewhere. A pull knob cable release usually located near the engine lid release beside the drivers door.
What VIN is your car?
Pat Garvey
Sep 20 2007, 09:40 PM
Were you ever able to get the trunk open?
And, we need your VIN for posterity. It's on a plate (small), on the drivers' side windshield post.
Let us know
Pat
