2.0 fuel injectors |
72914S |
Aug 31 2007, 08:00 AM
love this shot Group: Members Posts: 1,290 Joined: 10-July 03 From: Pensacola,Fl. Member No.: 900 Region Association: South East States |
Has anyone used anything other than the stock injector,with the stock d jet?
dr914@autoatlanta.com |
Aug 31 2007, 08:49 AM
914 Guru Group: Members Posts: 7,875 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
toon1 |
Aug 31 2007, 09:04 AM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
Has anyone used anything other than the stock injector,with the stock d jet? I am going to BUT I lhave a megasquirt. It is possible to use different injectors with the stock system BUT it will take a little work. Mst modern inj's. have an O ring top, not hose barb so a fuel rail will be needed. Also, most modern inj's. run at 43psi BUT there are plent of inj's out there that will flow the same amount of fuel as stock @ the 29 psi. I have looked into this extensivly, bottom line is YES it can be done with a little work and some research |
72914S |
Aug 31 2007, 10:02 AM
Thanks, Guess I`m going to send mine out for refurburshing.
rjames |
Aug 31 2007, 10:21 AM
I'm made of metal Group: Members Posts: 3,940 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
jk76.914 |
Aug 31 2007, 11:30 AM
I'm using Niehoff. Got them at PartsAmerica.com . They're the ones for 1974 Mercedes SE. Straight hoses, so I replaced them with the elbow hoses. $49 each brand new. Different nozzle design. Only one year and 2000 miles at this point, so it's early, but so far no problems. NAPA may sell Niehoff under either Niehoff or NAPA brand name.
kconway |
Aug 31 2007, 11:51 AM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
Thanks, Guess I`m going to send mine out for refurburshing. Last I checked NAPA still were carrying new ones... I just checked NAPA this morning, 73-74 2.0 Bosch injectors were NLA. (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 28th May 2024 - 11:54 PM |
