QUOTE(72914S @ Aug 31 2007, 07:00 AM)
Has anyone used anything other than the stock injector,with the stock d jet?
I am going to BUT I lhave a megasquirt.
It is possible to use different injectors with the stock system BUT it will take a little work. Mst modern inj's. have an O ring top, not hose barb so a fuel rail will be needed.
Also, most modern inj's. run at 43psi BUT there are plent of inj's out there that will flow the same amount of fuel as stock @ the 29 psi.
I have looked into this extensivly, bottom line is YES it can be done with a little work and some research
