Speedo angle drive, doesn't want to come off of the trans |
jimtab |
Aug 31 2007, 11:44 PM
Advanced Member Group: Members Posts: 3,477 Joined: 5-January 03 From: Pacifica, California Member No.: 91 Region Association: Northern California |
I am trying to change the speedo angle drive because it went to puppy heaven and I can't seem to get it to release...I took out the "lock bolt" in the back...duh but, I turn and turn on the nut on the piece into the trans and Nothing. the outer part of it came off of the part that's hooked to the trans (I think that may have had something to do with the problem....so where do I go from here...I hate to just start prying and banging without knowing what the hell I'm doing....I'm sure it's something simple and I'll feel stupid when you tell me so here's your chance to "do" me...HELP!
OK, never mind, the search engine started working again and I found Mikes VERY cogent article...relax, smoke em if you got em..... |
Sep 1 2007, 12:56 AM
I took out the "lock bolt" in the back...duh but, I turn and turn on the nut on the piece into the trans and Nothing. no girly turning action involved, just pull, old man ... (IMG:style_emoticons/default/poke.gif) Andy |
Dr Evil |
Sep 1 2007, 01:39 AM
Dude, what are you doing? Arent you out of your skill set (IMG:style_emoticons/default/tongue.gif) (IMG:style_emoticons/default/poke.gif)
jimtab |
Sep 1 2007, 10:05 AM
Mike....you have no itdea....now I can't get the nut and "cylinder" off of the drive that goes into the tranny....got it soaking in WD...I will prevail....eventually......
Cap'n Krusty |
Sep 1 2007, 10:13 AM
Why are you removing the drive pinion? It's an uncommon failure point. 99 times out of a hundred, it's the angle drive. Does the shaft turn as you rotate the tires (both must turn the same direction, or one must be locked, and it can be out of gear)? If it doesn't turn, you have internal tranny problems. The Cap'n
Dr Evil |
Sep 1 2007, 11:35 AM
Jim, it would have been easier to leave the angle drive in the tail. If you have it retained by the set bolt then you have something to leverage against (dont go too hard if it wont budge) when you crack the nut loose. Is it leaking from the inner seal?
jimtab |
Sep 1 2007, 12:01 PM
Jim, it would have been easier to leave the angle drive in the tail. If you have it retained by the set bolt then you have something to leverage against (dont go too hard if it wont budge) when you crack the nut loose. Is it leaking from the inner seal? Too late, I already pulled the whole thing out of the tranny, and finally with enough wd I got it apart, changed the seal o-ring and cleaned up everything...don't know if there is a leak as I drained the tranny (didn't know I could have left all that in...) now on the reinstall I need to take a look at the lock bolt threaded insert, I think the po must have overtorqued the thing because the threaded insert is about a 1/16 in. proud of the case...is the insert pressed in or threaded on the outside? Why don't the books give any info on this stuff? Why did I try this myself? Screw it I'm going to Sonoma for the rest of the day.... (IMG:style_emoticons/default/screwy.gif) |
jimtab |
Sep 1 2007, 12:03 PM
Why are you removing the drive pinion? It's an uncommon failure point. 99 times out of a hundred, it's the angle drive. Does the shaft turn as you rotate the tires (both must turn the same direction, or one must be locked, and it can be out of gear)? If it doesn't turn, you have internal tranny problems. The Cap'n Cap'n it was the angle drive, I just wasn't aware of how the whole thing went together I had already done all the "tests" to diagnose the failure point...just didn't know enough about what had to be done from there....obviously... (IMG:style_emoticons/default/blink.gif) |
Cap'n Krusty |
Sep 1 2007, 07:12 PM
Ask first, act later. Act first, then ask, then cry later. Glad you got it handled. Of course, it cost you a load of gear oil you wouldn't have needed. The Cap'n
jimtab |
Sep 2 2007, 12:01 AM
Ask first, act later. Act first, then ask, then cry later. Glad you got it handled. Of course, it cost you a load of gear oil you wouldn't have needed. The Cap'n I come from a long line of hardheads...ask anyone.... (IMG:style_emoticons/default/smile.gif) |
jimtab |
Sep 2 2007, 09:18 PM
Success, the baby is born, the part is installed and I have Speedo again....now if I could figure out the difference the 50 series tires make I'd actually know the speed I'm traveling....well, I'm sure some representative of the law enforcement community will come to my aid eventually....Thanks to all for your help and support.
Dr Evil |
Sep 2 2007, 09:23 PM
Good talking to ya today, man! Glad it worked out (IMG:style_emoticons/default/thumb3d.gif)
Lo-Fi Version | Time is now: 16th May 2024 - 05:14 PM |
