914 axle length, can someone tell me |
stock93 |
Dec 23 2003, 07:09 AM
Member Group: Members Posts: 333 Joined: 12-May 03 From: Huntsville, AL Member No.: 684 Region Association: South East States |
I'm looking for the length of the axle measured from end to end. I could pull mine and measure it but if someone knows the exact length off hand it would save me the trouble.
John |
Brad Roberts |
Dec 23 2003, 10:49 AM
The number 23 comes to mind.
Call the shop later today (around 11:30 am toll free) if somebody doesnt post the info here.. I'll measure one while we have you on the phone. 877-914-4YOU B |
JWest |
Dec 23 2003, 10:54 AM
Brad - measure a few different axles and post the numbers while you are at it. Oh yeah - "Please"
Brad Roberts |
Dec 23 2003, 10:56 AM
Ok.
Should have every axle available except maybe the 930 axle. B |
Eric_Shea |
Dec 23 2003, 11:21 AM
51.5cm or 20 1/4" (just a hair over) inches. Those are the 74's that are currently on my bench.
stock93 |
Dec 23 2003, 04:08 PM
Brad,
Thanks for the offer. I'm also needing to know if the splines on the end of the axle are the same as type 1/type2(bus)/type IV(thing,924/944). As I said, If no one knows I can pull one of my axles and try it myself. Are 914-6 axles different then 914/4 axles? Are the axles for a side shifter and a tail shifter a different length? What I'm trying to do is find the longest stock length axle I can find that has the type I/2/IV splines to build some longer/wider trailing arms for my railbuggy. I could get two longer axles from a vanagon auto if I can find them. John |
Lo-Fi Version | Time is now: 17th May 2024 - 08:33 AM |
