Decel Valve, Photo Request |
kconway |
Sep 12 2007, 08:42 AM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
I'm trying to install a decel valve in a 2.0 '74 car, yeah; I've heard that alot of folks don't use them. I think I've also read that you could damage your MPS if you remove it and since mine is new, I don't wanna do that.
Does anyone have a photo of how/where the valve is installed? Does it just float between the vacuum lines connected to it or am I missing some bracketry that secures it somewhere? Thanks, Kev |
type47 |
Sep 12 2007, 09:01 AM
don't have a photo at the moment but on a 73 or 74, i think the decel is mounted on the same bracket or at least next to the MPS (manifold pressure sensor)
rmital |
Sep 12 2007, 09:11 AM
Northeast optimist Group: Members Posts: 1,947 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
don't have a photo at the moment but on a 73 or 74, i think the decel is mounted on the same bracket or at least next to the MPS (manifold pressure sensor) yep...see upper right hand portion of pic. it uses one of the points on the MPS mounting bracket. Attached thumbnail(s) |
TJB/914 |
Sep 12 2007, 10:05 AM
Mid-Engn. Group: Members Posts: 4,336 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest |
don't have a photo at the moment but on a 73 or 74, i think the decel is mounted on the same bracket or at least next to the MPS (manifold pressure sensor) Here's a photo from my 74 2.0L D-Jet. It located just above the MPS on a small bracket. T Attached thumbnail(s) |
kconway |
Sep 12 2007, 10:20 AM
Got it.
Thanks! Kev |
Lo-Fi Version | Time is now: 9th June 2024 - 04:02 PM |
