Exhaust options, I need heat but can't spend a fortune |
RoninEclipse2G |
Sep 12 2007, 12:35 PM
Suby Geek Group: Members Posts: 232 Joined: 28-April 07 From: Parker, Colorado Member No.: 7,701 Region Association: Rocky Mountains |
hey guys, I'm trying to figure out how to fix my exhaust and keep heat without breaking the bank. I have a 74 2.0 currently with factory everything, and the heat exchangers and or manifold have become damaged/rusted to the point that I can't use the heat for fear of COx poisioning. not to mention I'm getting some annoying popping on downshifting for decelerating
I can have a simple full exhaust made out of stainless with a muffler for about $250, and I can weld up some sheetmetal boxes in place of heat exchangers for next to nothing. Are there any huge issues with this idea? I was thinking of setting up the heater box similar to the tangerine setups. |
type47 |
Sep 12 2007, 12:39 PM
if you are going to build your own exhaust system, obviously you'd want to copy the real deal as closely as possible for fitment issues. not interested in buying a set of SS heat exchangers (the easy, but expensive, way out)?
RoninEclipse2G |
Sep 12 2007, 12:42 PM
yeah, thought about the SS exchangers, I was looking at 2-3 times my possible budget just for those, and the stock muffler is shot as well
TROJANMAN |
Sep 12 2007, 01:15 PM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
Brant is local and has some SSI for sale. He posted them FS on the local board recently. I'll tell him about this.
RoninEclipse2G |
Sep 12 2007, 01:20 PM
thanks Greg, maybe it might be worth it, i wish I could get on the local board but my interweb acess is limited to work and it's blocked
RoninEclipse2G |
Sep 12 2007, 03:14 PM
bump
I'm not terribly concerned about keeping things stock right now, I just want something that will sound good and get me heat for the time being any suggestions or concerns I should be aware about guys? |
davep |
Sep 12 2007, 03:20 PM
914 Historian Group: Benefactors Posts: 5,154 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
All I can suggest are the SSI. Buy once and be done with it.
They fit, they provide heat, they will last the lifetime of the car. They will not kill you with exhaust leaks if you do it correctly. |
rhodyguy |
Sep 12 2007, 05:28 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
the $250 you're going to spend on something that might work is half way to REAL heat exchangers. bite the bullet. to spare your life you could remove the flex tubes that run from the he's to the body and cap the body tubes and drive the car. dress warmly.
k |
TROJANMAN |
Sep 12 2007, 05:47 PM
I spoke to Brant. He'll hook you up. He has a muffler too.
His email is Brant914 AT hotmail DOT com |
GeorgeRud |
Sep 12 2007, 06:24 PM
Kudos to the SSI system. You'll spend much more time and effort than it's worth to try to do better. If they only made them for 914-6s.
TedK |
Sep 13 2007, 11:54 AM
Member Group: Members Posts: 163 Joined: 1-August 07 From: Thousand Oaks, CA Member No.: 7,961 |
Kudos to the SSI system. You'll spend much more time and effort than it's worth to try to do better. If they only made them for 914-6s. Have you seen these? 914-6 Headers s Expensive! But nice. |
RoninEclipse2G |
Sep 13 2007, 01:57 PM
thanks for the info guys, if I can come up with the money I'll go with the SSI's that brant has, his price is quite fair from what I've seen
now to go search the couch for money *sigh* |
rhodyguy |
Sep 13 2007, 02:16 PM
smart move. 2 items you should never have to replace again. you will enjoy the warmth.
k |
alpha434 |
Sep 16 2007, 02:25 PM
My member number is no coincidence. Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains |
Use whatever header you want and an aircraft grade "Heat muff"
http://www.aircraftspruce.com/menus/ep/exh...components.html |
jwalters |
Sep 16 2007, 06:06 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
(IMG:style_emoticons/default/blink.gif) If you DO decide to go the cheap-out way. Do yourself a favour and install a carbon monoxide detector in the cabin area - your life is worth it. Not saying it will happen - but in aviation it is a matter which we all contend with daily. And seeing as how the set-up is very, very close. All it tkaes is one small insignificant leak and you and maybe others are dead..
If this messege worries you then good - it was meant to! |
swl |
Sep 16 2007, 06:19 PM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
smart move. 2 items you should never have to replace again. you will enjoy the warmth. k (IMG:style_emoticons/default/agree.gif) Bought mine in 76. The car is rotted away but the heat exchangers are like new and are going on the new car. |
Lo-Fi Version | Time is now: 10th June 2024 - 12:41 AM |
