Relay Boards, Does anyone rebuild them |
shelby/914 |
Sep 14 2007, 01:08 AM
Senior Member Group: Members Posts: 804 Joined: 24-August 05 From: Foxfield, Co Member No.: 4,655 Region Association: Rocky Mountains |
Just wondering? I think I may need one. Getting toooo much current out of the alternator, but it has been checked out by 2 shops and they say it is good. Have put on several voltage regulatrs with no change, so it may be in the board. Help
Gint |
Sep 14 2007, 07:08 AM
Mike Ginter Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Danny,
Joe D. was re-potting the nottoms of relay boards a couple of years ago. He might have some extras laying around. I can give you his number. |
SGB |
Sep 14 2007, 08:21 AM
Craig Laughlin- Camp 914- may do that....(just speculating)
dr914@autoatlanta.com |
Sep 14 2007, 09:38 AM
914 Guru Group: Members Posts: 7,896 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Just wondering? I think I may need one. Getting toooo much current out of the alternator, but it has been checked out by 2 shops and they say it is good. Have put on several voltage regulatrs with no change, so it may be in the board. Help maybe the wiring is out of sequence. If the voltage regulator has been replaced and the alternator is still overcharging it is not the relay board! |
shelby/914 |
Sep 14 2007, 10:13 AM
Exactly what does "wiring out of sequence mean?????????" I'm confused OBVIOUSLY
jd74914 |
Sep 14 2007, 10:21 AM
Its alive Group: Members Posts: 4,782 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
I think he means maybe the alternator is wired incorrectly.
BMartin914 |
Sep 14 2007, 10:24 AM
||| Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
Who wired the alternator to the harness Danny? I don't remember how the harness connects...is it individual wires on poles, or a connector.
I think "The Dr" means that one or more of thoise wires may be in the wrong place. You've only got a few - B+, Field, Ground and + right? Maybe that's the next thing to look at if you are not positive it's wired correctly - but it was doing this before you had it out too, so??? |
ConeDodger |
Sep 14 2007, 10:34 AM
Apex killer! Group: Members Posts: 23,613 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Who wired the alternator to the harness Danny? I don't remember how the harness connects...is it individual wires on poles, or a connector. I think "The Dr" means that one or more of thoise wires may be in the wrong place. You've only got a few - B+, Field, Ground and + right? Maybe that's the next thing to look at if you are not positive it's wired correctly - but it was doing this before you had it out too, so??? That is exactly what he means. Look at the positions of the wires in the three pronged connector. A couple of them may be switched around to the wrong spots. I have the same problem. |
BMartin914 |
Sep 14 2007, 10:44 AM
Who wired the alternator to the harness Danny? I don't remember how the harness connects...is it individual wires on poles, or a connector. I think "The Dr" means that one or more of thoise wires may be in the wrong place. You've only got a few - B+, Field, Ground and + right? Maybe that's the next thing to look at if you are not positive it's wired correctly - but it was doing this before you had it out too, so??? That is exactly what he means. Look at the positions of the wires in the three pronged connector. A couple of them may be switched around to the wrong spots. I have the same problem. That's easy. Wouldn't that be nice if that was the issue. |
shelby/914 |
Sep 14 2007, 09:01 PM
I"ll have to check out in the barn, but I think there is a spare alternator. I want to check the 3 prong plug but I thought that it would only go on one way, without force. You, Kevin and I installed everything on the long block before we installed it last year. and everything was fine as I recall but I'm old and my memory is failing. Yes it was overcharging, which is why I took the alt out to test it everyone said it was fin so put it back in and it still overcharges. We'll find it.
GeorgeRud |
Sep 15 2007, 12:25 AM
If you want to check out the relay board, just unplug the voltage regulator from it's position on the relay board, and plug it into the engine cable with the three pronged plug. I'd also recommend grounding the regulator through a mounting screw hole.
The relay board does nothing other than connect the three connections from the three prong engine harness to the relay. |
swl |
Sep 15 2007, 06:30 AM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
out of my league here but isn't the gererator light on the dash also associated with the voltage regulation? I'm sure I've read that if it is burned out bad things happen - just don't know what those 'bad things' are.
Lo-Fi Version | Time is now: 9th June 2024 - 07:25 PM |
