Wheel Spacer Caution, Installing new studs |
PRS914-6 |
Sep 21 2007, 06:16 PM
I was changing to longer studs and adding wheel spacers and noticed something to be careful of. This is 911 aluminum hubs
The new (Porsche OEM) studs have a slightly larger head and will not sit down on the surface properly without a spot face. If you look at the picture, you can see the lip from the old studs. The surface should be flat all the way across with no lip. |
mskala |
Sep 21 2007, 08:10 PM
I don't remember seeing that a few years back when I put longer
studs in my orig 914-6 hubs, but I plan on checking. Are the 911 hubs the same? |
Lo-Fi Version | Time is now: 19th May 2024 - 01:32 AM |
