I was changing to longer studs and adding wheel spacers and noticed something to be careful of. This is 911 aluminum hubs
The new (Porsche OEM) studs have a slightly larger head and will not sit down on the surface properly without a spot face. If you look at the picture, you can see the lip from the old studs. The surface should be flat all the way across with no lip.
