mrhurtalot |
VRRRRRRROOOOOOOOOM! ![]() ![]() Group: Members Posts: 323 Joined: 5-October 06 From: Yukon, Oklahoma Member No.: 6,996 ![]() |
need as much info as possible, looked on pelicans, nothing, IPB searches dont ever work well on here! haha.
this is desperately urgent, this may be my last weekend to drive her. so today is a total work day for me. (IMG:style_emoticons/default/smile.gif) TIA (IMG:style_emoticons/default/welder.gif) |
So.Cal.914 |
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None ![]() |
Your Haynes manual has a good section on it, tailshift, sideshift?
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,248 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
as paul asks, which flavor? what are the issues you need to adjust away?
k |
mrhurtalot |
the rod is just not the one that came with my car. the DAPO welded mine together, poorly. and well its a SIDE SHIFTER, last time i drove the car (before my little cv forgetfullness fiasco) i couldnt access my fourth or fifth gears. transmissions in fine condition. when i go to shift to 4th it feels like i dropped it into 2nd, and the same for 5th/3rd. my assumption was the shift linkage need adjustment.
So.Cal.914 |
If you don't have a haynes manual, try here; http://www.914world.com/bbs2/index.php?showtopic=52816
mrhurtalot |
ive got it sitting right here in front of me, page 90, 1973 onwards.. but i dont see how this will fix my "missing" gears? ill try it out though, since i dont know what else to do. hahah
So.Cal.914 |
Sounds like your typical 'out of adjustment' problem. Not enough throw, in the
right direction to engauge those gears, to much the other way and there is no first and reverse. Get it. (IMG:style_emoticons/default/smile.gif) |
mrhurtalot |
okay now im out in the garage, carpets out, etc. ive got the clamp bolt out, and now it says, turn the shift rod clockwise in the direction of travel.. WHAT?
basically, ive got the shift levers bottom part (as in the smaller section of the bend) vertical in relation to the car, all the way to the right against the stop. now i must twist something? im not understanding this!! |
joefri187 |
Newbie ![]() Group: Members Posts: 29 Joined: 1-November 05 From: Concord, CA Member No.: 5,047 Region Association: Northern California ![]() |
okay now im out in the garage, carpets out, etc. ive got the clamp bolt out, and now it says, turn the shift rod clockwise in the direction of travel.. WHAT? basically, ive got the shift levers bottom part (as in the smaller section of the bend) vertical in relation to the car, all the way to the right against the stop. now i must twist something? im not understanding this!! Take the access plate off that's back near the firewall. You should see the shift rod. Twist/turn the shift rod clockwise to the right. |
mrhurtalot |
ohhhh under the little armrest box? i shouldve thought about that...
meh, time to go back out now! |
mrhurtalot |
okay, so ive checked in the little hole under the box thing. and theres not a clamp thing in there or anything to turn, and the inspection plate was missing already...
whats the remedy here? im so totally lost now. pretty productive night otherwise, cv installed, muffler patched and installed, some other random little things. but not the linkage. (IMG:style_emoticons/default/sad.gif) |
purple |
Pigeon feeders attract me ![]() ![]() ![]() Group: Members Posts: 938 Joined: 24-July 07 From: Houston, TX Member No.: 7,942 Region Association: None ![]() |
you should have marked the rod and clamp at the bottom of the shifter so you know what you're doing. What I did is leave the clamping nut in, take a pair of vise-grips and hold on tight to the linkage at the rear cover. Then it's just a matter of getting the linkage into the clamp right where you want it. dont expect to get it right the first time.
BMartin914 |
||| ![]() ![]() ![]() Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest ![]() |
There is an access hole behind the shifter in the shifter plate. Take up the carpet to see it.
There is an 8mm (13mm head) bolt that you can see. This is the clamp that holds the shift rod to the shifter. Loosen the bolt and rotate the rod - clockwise or anti-clockwise, to gain back the throw in the right to left movement of the shifter. You want equal amounts in each direction and very small adjustments make a big difference. |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,196 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
The idea is that you loosen (don't remove) the clamp nut, then put the shift lever into a particular position, then move the front shift rod into the appropriate position to match the gear shift lever's.
At least, that's what the factory procedure has you do. Put the transmission in neutral, first. Loosen the clamp nut. Put a pair of vise-grips on the front shift rod--clamp them on through that hole at the back of the center tunnel, so you're not getting in your own way. Then put the gear shift lever all the way to the right, and make sure the part below the bend is straight up from a fore-and-aft perspective. Then crank the rod all the way to the right, and tighten the bolt. Try the shift pattern, and futz with the exact position of the gear shift lever versus the front shift rod until you get things set up the way you like them. --DD |
angerosa |
Member ![]() ![]() Group: Members Posts: 334 Joined: 21-August 07 From: Reston, VA Member No.: 8,023 Region Association: MidAtlantic Region ![]() |
I have to offer my two cents as well - Everyone is giving good advice. I just did this a couple of months ago. Mine isn't perfect but it's pretty close. I need to re-adjust.
If your linkage is welded together behind the firewall - the only adjustment you have (I believe) is the spline connection right under your shifter. Put your car in first, then unbolt the three metal bolts holding the shifter base to the linkage chanel. Undo the screw that holds the spline, adjust it so that first gear is further to the left (closer to you when in the drivers seat), that will make 4th and 5th reachable in the travel of your linkage. You should be able to shift into every gear with the clutch pushed in and the car not running. Make sure you can get into every one with it off and it should work with it on. To really see what's going on, I took off the linkage cover at the transmission, made adjustments and ran back and looked under the car to see what the position of the linkage looked like for each gear at the transmission. BTW - I have a tail shift, can you post a picture of where the side shift connects to the transmission under the car. I don't know I've ever seen one. |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,245 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
The idea is that you loosen (don't remove) the clamp nut, then put the shift lever into a particular position, then move the front shift rod into the appropriate position to match the gear shift lever's. (IMG:style_emoticons/default/agree.gif) no need to rotate the rod itself. leave everything connected and bolted down, simply losen the nut on the clamp right at the shifter (13mm socket) while in neutrual. you'll have to hold the shift lever when losening the bolt, otherwise it'll slip. then move the shift lever left or right just a bit, depending on what gears are missing and clamp back down. do the same forward/backwards if needed. repeat until all gears engage! (IMG:style_emoticons/default/smash.gif) Andy |
mrhurtalot |
ah. thats where i was confused, the haynes shows another clamping bolt in the rear back access hole on the forward rod. mine didnt even seem to have a spot for one to be. but the vice grip idea and Angerosas tips (as well as everyone elses!) seem to be what i need. ill run home probably tommorrow night, since i have a 230-530 engineering class tonight, and ill work on it some more.
some kids at my old school are trying to start a "main drag" thing, and i wanted to drop by saturday night and show off a bit. so thanks alot guys!! |
purple |
You will look an ass trying to drag race in a 914...just FYI
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
ah. thats where i was confused, the haynes shows another clamping bolt in the rear back access hole on the forward rod. mine didnt even seem to have a spot for one to be. but the vice grip idea and Angerosas tips (as well as everyone elses!) seem to be what i need. ill run home probably tommorrow night, since i have a 230-530 engineering class tonight, and ill work on it some more. some kids at my old school are trying to start a "main drag" thing, and i wanted to drop by saturday night and show off a bit. so thanks alot guys!! The second "clamp" is for the tailshifter linkage ...page 90 Fig. 5.28 Your linkage for a sideshifter ... page 89 Fig 5.27 |
cassidy_bolger |
Member ![]() ![]() Group: Members Posts: 106 Joined: 17-March 06 From: = Member No.: 5,737 Region Association: None ![]() |
Don't forget to check your bushings. If they are shot or missing, you might might not be able to get it adjusted no matter what you do - the rod will just be flopping around.
Lo-Fi Version | Time is now: 6th July 2025 - 12:56 AM |
