| J9146 |
Oct 6 2007, 02:37 PM
Newbie ![]() Group: Members Posts: 10 Joined: 13-May 05 From: San Diego CA Member No.: 4,073 |
Can some one post a picture of a stock 2.0 distributor in the motor?
I am having trouble with condenser hitting the tin so I can't adjust the timing. I set up drive gear from the book to 12 degrees. |
| jk76.914 |
Oct 6 2007, 02:45 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
Try moving each wire one location left or right, and then turning the body 90 degrees in the opposite direction and see if you can land in a better position. Sorry no pics. Maybe later.
Jim |
| Spoke |
Oct 6 2007, 06:12 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,351 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
Hope these help.
| jasons |
Oct 6 2007, 07:32 PM
Jackstand Extraordinaire ![]() ![]() ![]() ![]() Group: Members Posts: 2,011 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
Your dizzy drive may still not be indexed correctly. You can gingerly re-index the drive by inserting something into it and pulling it up and index it to where it needs to be. I did it with a 1/4" socket headed allen bit on an extension. I don't remember the size, but it was SAE not metric. It fit pretty snug in the hole in the center of the drive. I just put it in there, torqued it enough for it to get a grip, pulled up and rotated the drive one or two teeth.
I would think moving the plug wires could be a problem if you have DJet. Because, the trigger points in the dizzy wouldn't be in sync with the ignition order. |
| J9146 |
Oct 7 2007, 09:14 PM
Thanks Jerry when I pulled the condenser off I forgot it was attached to the vacuum advance instead of the wire hold down.
Lo-Fi Version | Time is now: 12th March 2026 - 09:23 PM |
