Mallory Unilite Distributor, Installation in 914 2.0L questions.... |
Joseph Mills |
Mar 17 2003, 05:01 PM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
Just a few questions. Waiting to receive this distributor. It is replacing a 009 and will be used with a Bosch blue coil and an MSD-5 electronic ignition (no rev-limiter). Any advantage gained by upgrading the coil or will it work just fine?
I know the unit is much larger than my 009. Anything special I need to be aware of for installation of the Mallory in a T4 engine (adaptors, clearance)? Is a "ballast resistor" required for this combination? If so, exactly what is a ballast resistor and what does it do? This will be my first time swapping out a distributor, so any info is appreciated. Joseph 75 2.0L AX bound |
Brad Roberts |
Mar 17 2003, 08:02 PM
Hey Joseph.
I just installed a MSD dizzy which had about the same cap size as the Mallory. I had to take a soft face hammer to the engine tin so the number 3 plug wire would go on. Its a tight fit, but I easily adjusted the timing today and had NO issues with turning the dizzy. You can see in my pic where I marked it with the spot that needed room. B |
Lo-Fi Version | Time is now: 20th May 2024 - 12:08 AM |
