Mallory Unilite Distributor, Installation in 914 2.0L questions.... |
Joseph Mills |
Mar 17 2003, 05:01 PM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
Just a few questions. Waiting to receive this distributor. It is replacing a 009 and will be used with a Bosch blue coil and an MSD-5 electronic ignition (no rev-limiter). Any advantage gained by upgrading the coil or will it work just fine?
I know the unit is much larger than my 009. Anything special I need to be aware of for installation of the Mallory in a T4 engine (adaptors, clearance)? Is a "ballast resistor" required for this combination? If so, exactly what is a ballast resistor and what does it do? This will be my first time swapping out a distributor, so any info is appreciated. Joseph 75 2.0L AX bound |
campbellcj |
Mar 17 2003, 08:23 PM
I can't Re Member Group: Members Posts: 4,544 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Don't forget you will most likely need the "remote pressure sender" if you're running a VDO oil pressure gauge.
I think we already discussed that in an earlier thread. Pretty sure that's what the hose going across B's pic is. |
Lo-Fi Version | Time is now: 8th May 2024 - 11:42 PM |
