Engine tin codes, Your help needed to figure them out |
JeffBowlsby |
Oct 11 2007, 10:49 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
We have collected info and photos of the engine tin codes on various 914s, but the info is incomplete. The meaning of the codes is a mystery and you can help figure it out! Please review the list of info we have to date and compare it to the markings on your tin. If your code is not on the list please post a photo of the marking and a photo of the emission label found above the drivers side relay plate. We especially need data from the 1975-76 914s and any that are missing from the earlier years, or better photos of any of the codes we have to date. You'll get kudos for your contributions on the webpage.
The data we have so far is under Group E on my PLM page found here: http://members.rennlist.com/914_collectibles/PLM.htm We need photos like these two: THANKS! (IMG:style_emoticons/default/thumb3d.gif) Attached image(s) |
JeffBowlsby |
Oct 19 2007, 10:40 PM
Kenny, do you have access to the emission label above the relay plate for this car? Does the label says it meets California standards or is it 49-state only? Does the case SN start with EA or EB?
orange914 |
Jan 9 2008, 06:28 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
Kenny, do you have access to the emission label above the relay plate for this car? Does the label says it meets California standards or is it 49-state only? Does the case SN start with EA or EB? oops... dropped the ball, sorry. i'll try to get it this week end. i did look for the block# and couldnt find it as its probably still buried under the misc. it's not in the same spot as the ga. i'm building antway, where exactly is it? p.s. did you get the p.m. about the harness & m.p.s.? mike |
Lo-Fi Version | Time is now: 19th May 2024 - 02:07 AM |
