Carb fuel pump routing |
KaptKaos |
Oct 14 2007, 01:56 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
I am putting in new lines for my carbs. The hard line comes under the car, then connects to the old pumpt and filter. I am using the CB rotary pump and it's almost 12 inches long all in.
There is a mounting point for the fuel filter under the car, but if I try and mount the new filter there, then the lines under the car will be doing loops. Can i mount the pump underneath and then the filter above the tin? Is that a bad idea? Should I be doing this another way (other than moving the pump to the front). Let me know. Thanks! |
Lo-Fi Version | Time is now: 18th May 2024 - 09:44 PM |
