Testing injectors, ? |
Hammy |
Oct 16 2007, 10:09 PM
mr. Wonderful Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California |
How do I do a visual test/check on fuel injectors outside the car on the bench? Any way to tell they're spraying right? I don't want to install this engine and find the injectors are crap.
Spoke |
Oct 17 2007, 06:53 AM
Jerry Group: Members Posts: 6,986 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I'm in the same boat trying to get a FI system working again after years of sitting in a box. I have dual Weber carbs as a back-up but really would like to get the FI working.
I was thinking to test the injectors (I have 8), I would connect them to a length of hose, fill the hose with Kerosene, and connect the other end to my compressor. Pump up to 30-40 psi, and connect the injector to a battery through a push button switch. My goal is to see if the injectors work and if the spray pattern is ok by spraying into a jar. Will this work? Will the kero damage the injectors? Spoke |
Lo-Fi Version | Time is now: 23rd May 2024 - 09:49 PM |
