Testing injectors, ? |
Hammy |
Oct 16 2007, 10:09 PM
mr. Wonderful Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California |
How do I do a visual test/check on fuel injectors outside the car on the bench? Any way to tell they're spraying right? I don't want to install this engine and find the injectors are crap.
toon1 |
Nov 11 2007, 04:52 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
What injectors work and what are the modifications that are necessary? Has anyone ever had any luck using a modern injector as a replacement? Sorry for the slight hijack! -Chris Yes, it can be done, it takes a little work. to use different inj's with the current fuel system, you will need to find an inj', that is, Low imp. 21lbs/hr@ around 29psi of fuel pressure. with A new fuel pump and reg. you can run higher pressures and still get the same inj. fuel flow A fuel rail will need to be fabbed because the newer inj's have an Oring ontop not a hose barb,no big deal. The pulse width on the stock system cannot be changed so the flow rate of the inj's have to be close to the same as stock. I am going to be running ford prob inj's that flow 21lbs/ hr @ 43psi HIgh imp. BUT I am using megasquirt so I can adjust things There are plenty of options, avail for the stock system. |
Lo-Fi Version | Time is now: 18th May 2024 - 07:11 AM |
