I'm half done with my car, right?, Starting RUST & Body repair.. |
jaminM3 |
Oct 17 2007, 12:18 PM
Member Group: Members Posts: 418 Joined: 23-March 07 From: SLC, UT Member No.: 7,619 Region Association: Intermountain Region |
I have observed from months of searching this site that the typical build goes through four stages:
1. Buy 914 (IMG:style_emoticons/default/shades.gif) 2. Put 914 on jack stands (IMG:style_emoticons/default/welder.gif) 3. Take 914 off of jack stands (IMG:style_emoticons/default/aktion035.gif) 4. drive (IMG:style_emoticons/default/driving.gif) According to this model, I am halfway done.... Attached image(s) |
thesey914 |
Oct 17 2007, 01:07 PM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
No no no -you're only halfway started -you're about to get a dose of DWD
rick 918-S |
Oct 17 2007, 01:10 PM
Hey nice rack! -Celette Group: Members Posts: 20,456 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
(IMG:style_emoticons/default/agree.gif) DWD... (IMG:style_emoticons/default/w00t.gif)
jaminM3 |
Oct 17 2007, 01:11 PM
DWD??
I am going to start stripping rust to fix the jack points and hell hole and that is all the rust as far as I know so far. I see pictures of cars that are body color in the inner fenders, but mine is black and undercoated. Did a PO do this? either way I'm happy because I think it helped protect the metal from rust.. |
rick 918-S |
Oct 17 2007, 01:20 PM
I tried to Google it for you but didn't get a good hit. (IMG:style_emoticons/default/confused24.gif) Dirk Wrights Disease. (IMG:style_emoticons/default/av-943.gif)
How that baby coming? |
markb |
Oct 17 2007, 01:21 PM
DWD= Dirk Wright Disease
Dirk was a member of one of the early internet clubs, and started a refurb of his car. One thing lead to another "while I'm in there I might as well do...." thing. It got so bad that they named the disease after him. I'm not sure what ever happened to him. Maybe he's still out there under his 914 somewhere. (IMG:style_emoticons/default/dry.gif) |
jhadler |
Oct 17 2007, 01:31 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
DWD= Dirk Wright Disease Dirk was a member of one of the early internet clubs, and started a refurb of his car. One thing lead to another "while I'm in there I might as well do...." thing. It got so bad that they named the disease after him. I'm not sure what ever happened to him. Maybe he's still out there under his 914 somewhere. (IMG:style_emoticons/default/dry.gif) Actually, it was an early 911 (SC?). But the story is nonetheless true. That car was spread out across the garage floor like an NTSB investigation of a plane crash. I honestly don't remember if he got it all completely back together before he sold it or not. Dave Darling would know, I moved away from the Bay Area when it was still disassembled. -Josh2 |
jaminM3 |
Oct 17 2007, 01:51 PM
Hey Rick, the baby is going fine from what I can tell. Six more weeks..
I actually have a plan so DWD doesn't happen. I am not going to strip it down to nothing. I am going to fix the rust and do an exterior only paint job and try to get it back on the road ASAP. ... well, I did buy some 5 lug fuchs and sent the heads off to Len... Oh crap DWD it is then.... (IMG:style_emoticons/default/sad2.gif) (IMG:style_emoticons/default/owned.gif) |
jaminM3 |
Oct 23 2007, 09:22 PM
I ground away some of the rust on the longs and it looks like I may have to cut out a piece of the long, is this right?
Can someone tell me what is recommended in this situation? Jeff Hail ? I'm all geeked up and ready to go (IMG:style_emoticons/default/thumb3d.gif) Attached thumbnail(s) Attached image(s) |
1970 Neun vierzehn |
Oct 23 2007, 10:40 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
Ben,
1st...... (IMG:style_emoticons/default/clap56.gif) , for saving another 914 2nd.....make sure your tetanus shots are up to date 3rd.....the DWD is real, first you just want to take care of the structural rust and hell hole, then you think, why not attend to the trunks, then its, well, I might as well pull the gas tank and do the cowl, then when you get nice fresh body seam sealer, primer, then final coat on, its.....sheesh...I can't put an old nasty pedal cluster back in there, or grungy calipers, or a fuzzy gas tank, or a cracked dash top, and on, and on, and on, and on........... (IMG:style_emoticons/default/biggrin.gif) Good luck and remember, there's a strong, supportive group of us on this Forum to offer support and advice. Paul |
jaminM3 |
Oct 24 2007, 03:50 PM
I think I also inhereted someone else's DWD project. I bought it off CL locally and he had already ripped apart the engine, interior and gas tank. The suspension and dash are still in and that is it. I have baby formula cans with screws, bolts, nuts, and all the other parts he took off. I should start a thread called " identify this 914 bolt". Or I was even thinking about picking up another car to see where everything goes. (IMG:style_emoticons/default/confused24.gif)
type47 |
Oct 24 2007, 05:36 PM
I was even thinking about picking up another car ... you're going to fit in here (IMG:style_emoticons/default/laugh.gif) |
PanelBilly |
Oct 24 2007, 09:11 PM
914 Guru Group: Members Posts: 5,805 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Rust repair, its like swimming. You have to get totally wet to do it right. Set aside a few years to work on your car and strip off everything so you'll have a clean canvus to work with. If you want a car to drive, buy another one.
jaminM3 |
Nov 4 2007, 11:29 PM
Well, I copied the seat belt to door hinge brace from michelko's awesome thread: http://www.914world.com/bbs2/index.php?showtopic=16748
and I have cut out the crushed front fender and started cutting up the new fender to fit. I am also on the list fo the steel flair group buy. DWD (IMG:style_emoticons/default/screwy.gif) Attached thumbnail(s) Attached image(s) |
Nov 5 2007, 03:04 AM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Actually, it was an early 911 (SC?). No, it was a 914. IIRC, he decided to replace the pedal pads one day. Which led to re-bushing the pedal cluster. Which led to both rebuilding the brakes, and cutting out chunks of the floor pan to replace 'em. And I don't really recall where he stopped, but from the sound of it he really went off the deep end. (Zinc plating the brake rotors? Huh??) I think someone on here checked up on him a year or two ago, and the 914 was long gone. --DD |
jaminM3 |
Mar 31 2011, 09:55 PM
Wow I haven't done much work on here lately..
That may be because I bought a '74 and have been busy moving the fuel pump from the back to the front. Then I did a 5 lug conversion. then I replaced the sail vinyl and some of the rubber. Well, enough about the new teener. After reading every metal work and fender repair thread on this site, I think I should remove the headlight bucket and replace each piece separate from each other. Like the front panel vs the inner fender vs outer fender. I think the trunk floor is still a little crushed. I should probably make sure the suspension points are not wacked too... |
Lo-Fi Version | Time is now: 14th May 2024 - 01:54 AM |
