easiest way to remove mirror from windshield?, ws out of car |
rhodyguy |
Oct 18 2007, 06:46 AM
i run an "evil' mirror. just pour some mek or similar solvent around the base and the mirror should release? i'd hate to break it now.
k |
URY914 |
Oct 18 2007, 07:09 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,578 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
tdgray |
Oct 18 2007, 07:11 AM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
Go to your local FLAPS... they have a solvent specifically designed to do this.
Can't remember what it is but it is right by the adhesive to put it back on. |
rhodyguy |
Oct 18 2007, 07:32 AM
i was going to take paul's advice. i think i'll take your path instead. thanks!!
URY914 |
Oct 18 2007, 07:37 AM
You'll use that hammer for something else, I'm sure.
rhodyguy |
Oct 18 2007, 07:42 AM
actually, it's my engine tin adj tool for installing a mallory dist. (IMG:style_emoticons/default/wink.gif)
warrenoliver |
Oct 18 2007, 11:53 AM
Member Group: Members Posts: 363 Joined: 11-November 06 From: McFarland, Wisconsin Member No.: 7,199 Region Association: Upper MidWest |
I recently did this while the windshield was in the car, so it was a little more difficult. I looked at the solvent @ the FLAPS and found that it was nothing more than acetone. So, instead I bought a pint of the stuff (was on the shelf @ FLAPS).
I took a few drops of acetone and let it seep in around the edges of the mirror mount. Every few minutes, I put a little more on it and let it soak (on my windshield, some of it ran down the windshield and I had to be careful not to let it drip on the dash). I let it sit overnight and the next day it easily twisted right off with my hand. Just be patient, let it do its thing. BTW, acetone is a great way to remove superglue. I use it routinely to remove glass that is superglued to a device at work. I just soak the whole thing overnight and the superglue is gone. YMMV (IMG:style_emoticons/default/biggrin.gif) Warrenoliver |
TINCAN914 |
Oct 18 2007, 12:22 PM
Summer's Commin... Group: Members Posts: 2,440 Joined: 18-August 05 From: Colorado Springs, CO. Member No.: 4,611 Region Association: Rocky Mountains |
Just to add my .02...
I used a putty knife and a rubber malet, couple taps and it came free. I did this twice. When removinv the mirror from the factory shield and again when I mounted the damn thing to low... (IMG:style_emoticons/default/headbang.gif) |
Project 6 |
Oct 18 2007, 12:53 PM
large member Group: Members Posts: 359 Joined: 30-December 02 From: Utah Member No.: 51 Region Association: None |
Mine just falls off when I look at it wrong.
rhodyguy |
Oct 18 2007, 08:17 PM
acetone? i'll break out some fingernail polish remover and see how it works.
Lo-Fi Version | Time is now: 15th May 2024 - 02:02 PM |
