Windshield wiper motor, removal |
whitey |
Oct 22 2007, 01:00 PM
Member Group: Members Posts: 146 Joined: 8-February 07 From: Coto de Caza Member No.: 7,508 |
What is the proper way to get the wiper assembly out. I have the two bolts at the wipers removed. I need to remove the 10mm nut/bolt behind the motor assembly. Do you get to it from the cockpit or from the trunk area? If from the cockpit, do you have to remove the instrument cluster? Do you take each gauge out before you can get the cluster plate out?
Thanks |
dflesburg |
Oct 22 2007, 01:11 PM
Senior Member Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
I think you have to pull the gas tank, then the blower fan.
If anyone knows how to aviod that, let me know. |
whitey |
Oct 22 2007, 04:19 PM
I have the tank and blower removed. I just can't get to the bolt/nut behind the motor. Do I access this from the trunk?
GaroldShaffer |
Oct 22 2007, 05:06 PM
No, under the dash kind of behind the ventalation controls
Lo-Fi Version | Time is now: 17th May 2024 - 12:24 AM |
