whitey
Oct 22 2007, 01:00 PM
What is the proper way to get the wiper assembly out. I have the two bolts at the wipers removed. I need to remove the 10mm nut/bolt behind the motor assembly. Do you get to it from the cockpit or from the trunk area? If from the cockpit, do you have to remove the instrument cluster? Do you take each gauge out before you can get the cluster plate out?
Thanks
dflesburg
Oct 22 2007, 01:11 PM
I think you have to pull the gas tank, then the blower fan.
If anyone knows how to aviod that, let me know.
whitey
Oct 22 2007, 04:19 PM
I have the tank and blower removed. I just can't get to the bolt/nut behind the motor. Do I access this from the trunk?
GaroldShaffer
Oct 22 2007, 05:06 PM
No, under the dash kind of behind the ventalation controls
