Brown paper heater hose, In the engine compartment |
Scott S |
Oct 22 2007, 02:17 PM
Small Member Group: Members Posts: 1,697 Joined: 30-April 03 From: Colorado Member No.: 633 |
Hi All -
I like the look of the vintage brown paper heater hose (mine are a black plastic). Where is the best place to find this - is it still available? |
Scott S |
Oct 22 2007, 02:20 PM
Hi All - I like the look of the vintage brown paper heater hose (mine are a black plastic). Where is the best place to find this - is it still available? This stuff.... Attached image(s) |
Pat Garvey |
Oct 22 2007, 06:06 PM
I will speak ONLY to 1972 late models. It should be the black plastic flexible hose. Paper in the front, but only there.
Pat |
Ferg |
Oct 22 2007, 08:09 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
Scott, Conway said he could still order it... I need to bug him anyhow because I need some for my front trunk. I think it comes in 3 foot sections. Want me to double my order?
Ferg |
Eric_Shea |
Oct 23 2007, 12:36 AM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Ferg |
Oct 23 2007, 10:45 AM
I need to go there tomorrow anyhow, and have a scrap piece that I'll bring. Conway says he has some on the shelf, if it's the same, I'll snag it and find out where he gets it from. Ferg |
Eric_Shea |
Oct 23 2007, 11:27 AM
I'm in the same boat... front trunk. Only the drivers side, everything else is perfect. (IMG:style_emoticons/default/confused24.gif)
jonferns |
Oct 23 2007, 05:30 PM
would it be the same for the 74 front trunk...because I am in desperate need for new ones
anyone know where i can source them? -JON |
1970 Neun vierzehn |
Oct 23 2007, 10:54 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
All,
AA shows several different types of heater hose on their 'net site, it might be worth talking with them about exactly what you are looking for. Paul |
Cap'n Krusty |
Oct 30 2007, 08:24 PM
Black plastic was original. It's relatively thin material, and corrugated for most of its length, the exception being at each end, where the clamps go to secure it over the metal (or molded plastic) fittings. Paper hose is NOT original or correct for heater hose in the engine compartment of the 4 cylinder cars. It can be found, however, in a smaller diameter as part of the thermostatic intake air pre-heat apparatus on the 1972 engines.
The Cap'n |
Pat Garvey |
Nov 1 2007, 09:18 PM
Black plastic was original. It's relatively thin material, and corrugated for most of its length, the exception being at each end, where the clamps go to secure it over the metal (or molded plastic) fittings. Paper hose is NOT original or correct for heater hose in the engine compartment of the 4 cylinder cars. It can be found, however, in a smaller diameter as part of the thermostatic intake air pre-heat apparatus on the 1972 engines. The Cap'n Agree with the thermo intake pre-heat pipe, but it was black (not brown) paper, and I'm pretty sure it was aluminized on the inside. Pat |
Eric_Shea |
Nov 2 2007, 10:24 PM
QUOTE I need to go there tomorrow anyhow, and have a scrap piece that I'll bring. Conway says he has some on the shelf, if it's the same, I'll snag it and find out where he gets it from. Any luck? |
Ferg |
Nov 4 2007, 05:16 PM
Ferg |
Nov 8 2007, 10:36 PM
OK, so sounds like this stuff is no longer in the normal channels, and has been replaced with the aluminum looking crappy stuff.
I am hoping to get my hands on as much as I can though, I "think" I found some leftovers. Will keep you guys posted. Ferg |
Ferg |
Nov 13 2007, 04:00 PM
OK, found a source, it's not NOS, but OE made in Germany. It looks exactly like the stuff in the photo of 1970 Neun vierzehn's resto.
Brown paper outside, silver foil inside. Comes in 1 meter sections 27.50 each, no shipping charge to me. add shipping from me to you. It's my understanding that 7 or so 1 meter sections are available, and once they are gone (IMG:style_emoticons/default/confused24.gif) I am getting two for myself. Anyone else? PM me by Thursday. Ferg |
JeffBowlsby |
Nov 13 2007, 04:19 PM
914 Wiring Harnesses Group: Members Posts: 8,492 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I am in Mike. I need enough for 2 cars, front trunk only. I presume one 1-meter length will do 1 car both sides? I ahve not measufred them. If so, I am in for two lengths. Let me know payment details.
Ferg |
Nov 13 2007, 05:03 PM
I am in Mike. I need enough for 2 cars, front trunk only. I presume one 1-meter length will do 1 car both sides? I ahve not measufred them. If so, I am in for two lengths. Let me know payment details. Not sure if one section will cover the front trunk, that's what I need it for as well. If you measure let us know. I won't be able to look at my own car tonight. got you down for two. Ferg |
Eric_Shea |
Nov 14 2007, 12:46 AM
1 for me please..
davep |
Nov 14 2007, 06:41 AM
914 Historian Group: Benefactors Posts: 5,138 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
1 for me please.
Ferg |
Nov 14 2007, 03:02 PM
OK so with 2 for myself, that brings the count to 6.
Say tomorrow noon is the cut off, to get the order in. Ferg |
Lo-Fi Version | Time is now: 8th May 2024 - 05:38 PM |
