fuel regulator for single line carb setup question |
rfuerst911sc |
Oct 28 2007, 09:51 AM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
I will be installing a 3.0 into my 75 chassis and will be running Weber 40 carbs. I also will be installing the single stainless fuel line from Tangerine Racing so I won't have a return line. Also I will be useing a Facet fuel pump. I am familiar with the 2 line fuel regulator ( supply + return ) as I have it on my SC with PMO's but what kind of regulator do you use when you only have the feed line? And can these be purchased with a gauge so fuel pressure can be monitored?
Lo-Fi Version | Time is now: 18th May 2024 - 06:44 AM |
