Richard's progress thread |
Richard Casto |
Oct 31 2007, 09:13 PM
Blue Sky Motorsports, LLC Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States |
A little history first...
This is my third 914 and it will be a keeper. First two are from my college days in the late 1980's but both of those are gone (1st was totalled in a crash, the second had terminal rust and eventually became a parts car) Fast forward roughly 20 years. Got married, had two kids and I decided I could not continue to put off building my dream car. While I had always wanted an original 914/6, I also wanted a general purpose fun car (Street, Autocross and Track) that would have had more power and safety features than a stock 914/6. I can't afford to have multiple 914s (a stock 914/4, a 914/4 with a modern Type IV, a stock 914/6, a 914/6 GT Clone, a track only 914, etc.), so rather than molest a "real" 914/6 to build my dream "six", I decided to start with a regular 914/4 and do a six swap. This car was purchased in 8/2005. Over the past two years I have disassembled the entire car and am now at the point of doing repair and refurbishment. Which is why I picked now as the time to do the progress thread (who wants to read about the dis-assembly of a car!) Goals for the car...
I have my own website that contains a higher level of detail on specific sections of the car as well as a more detailed general Blog. I currently host this at home and sometimes the server is down, but it is up most of the time. You can find that here... http://motorsport.zyyz.com/project_914.htm |
Richard Casto |
Jul 7 2008, 12:40 PM
On the left is part of the double wall that will be right behind the new skin. On the right is the inner double wall that is where the passenger seatbelt mount passes through. This is the first time I have used weld through primer. I had researched to try to determine what primers are good. It seems like people like "U-Pol Weld #2". This is the product from the UK that is supposed to be good. I don't have anything to compare it to, but I can say that it is not easy to weld on. If you spray, let it dry and then weld, it is hard to get a good arc started. Then the pool may tend to lay on top of it a bit. So while I am still using it, if I have to weld a rosette plug, what I now do is take an air powered die grinder and rough up the surface (effectively grinding off the primer) on the inside of the rosette hole. I am then able to weld it up just fine. Here are both welded into place. I have not ground down the welds at this point. |
Lo-Fi Version | Time is now: 28th April 2024 - 06:38 PM |
