Richard's progress thread |
Richard Casto |
Oct 31 2007, 09:13 PM
Blue Sky Motorsports, LLC Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States |
A little history first...
This is my third 914 and it will be a keeper. First two are from my college days in the late 1980's but both of those are gone (1st was totalled in a crash, the second had terminal rust and eventually became a parts car) Fast forward roughly 20 years. Got married, had two kids and I decided I could not continue to put off building my dream car. While I had always wanted an original 914/6, I also wanted a general purpose fun car (Street, Autocross and Track) that would have had more power and safety features than a stock 914/6. I can't afford to have multiple 914s (a stock 914/4, a 914/4 with a modern Type IV, a stock 914/6, a 914/6 GT Clone, a track only 914, etc.), so rather than molest a "real" 914/6 to build my dream "six", I decided to start with a regular 914/4 and do a six swap. This car was purchased in 8/2005. Over the past two years I have disassembled the entire car and am now at the point of doing repair and refurbishment. Which is why I picked now as the time to do the progress thread (who wants to read about the dis-assembly of a car!) Goals for the car...
I have my own website that contains a higher level of detail on specific sections of the car as well as a more detailed general Blog. I currently host this at home and sometimes the server is down, but it is up most of the time. You can find that here... http://motorsport.zyyz.com/project_914.htm |
3d914 |
Jul 23 2008, 08:40 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
Richard,
THis is awesome stuff. I have taken on a similar rebuild project, but have begun to cringe at the idea of digging into the Hell Hole! I have a couple of questions . . . 1) Are there any cross-section drawings or photos that show the layers of metal for the rear passenger longs - near where the battery tray leaks? Or do I just have to cut through one layer at a time? 2) You may have mentioned it in a previous posting (and if so point me to the page) - but what type & model of welder are you using (Mig, Tig, Flux)? Thanks & keep up the great job! |
Richard Casto |
Jul 24 2008, 08:54 AM
Richard, THis is awesome stuff. I have taken on a similar rebuild project, but have begun to cringe at the idea of digging into the Hell Hole! I have a couple of questions . . . 1) Are there any cross-section drawings or photos that show the layers of metal for the rear passenger longs - near where the battery tray leaks? Or do I just have to cut through one layer at a time? 2) You may have mentioned it in a previous posting (and if so point me to the page) - but what type & model of welder are you using (Mig, Tig, Flux)? Thanks & keep up the great job! Hey don't be afraid. It is scary, but you will sleep better at night knowing it is done. (IMG:style_emoticons/default/biggrin.gif) I have felt depressed at times when it was all torn and cut apart, but now that it is going back together I feel much better. (IMG:style_emoticons/default/aktion035.gif) Regarding question #1. Here are two good threads... http://www.914world.com/bbs2/index.php?showtopic=66790 http://www.914world.com/bbs2/index.php?showtopic=66637 The first is AA showing a bunch of repro parts welded together. Look for the post #13 from McMark. He talks about how the repro parts are not 100% accurate in that the section below the battery on the inside is two layers. The inner layer has a corrogated shape (which the repro has as well). Then there is an outer skin that covers this. Both make a "C" shape and it is the outer skin that has the flang that is spot welded to the rest of the car. In the second you can see some nice detail photos taken from where the jack receiver would be back into the inside of the hell hole. You can see the corrogated metal and how the "C" is built and how the corrogated part is not as wide as the rest. I have some similar photos in this thread and on my site, but I think these are a bit better than mine. Regarding #2. I am using a basic 220V Lincoln MIG unit with non-flux .025 wire (using gas). Because this is thin metal welding so a 110V unit would be just fine. I really expensive unit with more flexability on settings would work even better (with regards to setting on the welder), but I think that successfully welding thin sheet metal is 90% technique. Just practice a lot and get used to what setting/technique work well for you. (IMG:style_emoticons/default/welder.gif) Good luck on your car! Richard |
Lo-Fi Version | Time is now: 28th April 2024 - 08:49 PM |
