Richard's progress thread |
Richard Casto |
Oct 31 2007, 09:13 PM
Blue Sky Motorsports, LLC Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States |
A little history first...
This is my third 914 and it will be a keeper. First two are from my college days in the late 1980's but both of those are gone (1st was totalled in a crash, the second had terminal rust and eventually became a parts car) Fast forward roughly 20 years. Got married, had two kids and I decided I could not continue to put off building my dream car. While I had always wanted an original 914/6, I also wanted a general purpose fun car (Street, Autocross and Track) that would have had more power and safety features than a stock 914/6. I can't afford to have multiple 914s (a stock 914/4, a 914/4 with a modern Type IV, a stock 914/6, a 914/6 GT Clone, a track only 914, etc.), so rather than molest a "real" 914/6 to build my dream "six", I decided to start with a regular 914/4 and do a six swap. This car was purchased in 8/2005. Over the past two years I have disassembled the entire car and am now at the point of doing repair and refurbishment. Which is why I picked now as the time to do the progress thread (who wants to read about the dis-assembly of a car!) Goals for the car...
I have my own website that contains a higher level of detail on specific sections of the car as well as a more detailed general Blog. I currently host this at home and sometimes the server is down, but it is up most of the time. You can find that here... http://motorsport.zyyz.com/project_914.htm |
Richard Casto |
Oct 31 2007, 09:47 PM
This past week, I decided to dive in and really start cutting out the rusty spots.
The car is supported on the rotisserie. I also have the standard braces between the shoulder seatbelt mounts and door frame, I also built some extra long jack stands to support the front and rear of the longitudinal while I work on the passenger longitudinal and hell hole. It was kind of scary and exciting to cut into the car. (IMG:style_emoticons/default/biggrin.gif) It is about as bad as I expected. With the car on the rotisserie and doing 360 barrel roles you could hear all kinds of rust rolling around inside. A lot of this flaky rust also comes from the hell hole area and it has just migrated to the lowest part of the car. Still, I am not happy because I am pretty sure I am going to have to rebuild the bottom part of the inner longitudinal. I have the outside repro part from Restoration Design, but I see a lot of fabrication work in my future. This photo really shows what I am trying to fix. You can see my fingers through the gap behind the straight edge. This is behind the jack receiver point (jack receiver was mostly removed by the PO) and under the hell hole. The double walled section here has rusted through enough that the bottom is no longer strong. The car has been jacked up on this and because of the weakness, it has collapsed/crushed part of the box section here. That is what is causing the gap. Much of this area needs to be replaced. Here we are looking inside of that hole (I actually cut more of the area off around where the jack receiver mounts after the photo above). We are looking back toward where the rear suspension console mounts. There is some debris up in the top as a result of doing barrel rolls on the rotisserie. But after I vaccumed that out, it looks like the inner corrugated wall of this section is in good shape other than the very bottom that you can't see in this photo |
Lo-Fi Version | Time is now: 28th April 2024 - 05:24 PM |
