Richard's progress thread |
Richard Casto |
Oct 31 2007, 09:13 PM
Blue Sky Motorsports, LLC Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States |
A little history first...
This is my third 914 and it will be a keeper. First two are from my college days in the late 1980's but both of those are gone (1st was totalled in a crash, the second had terminal rust and eventually became a parts car) Fast forward roughly 20 years. Got married, had two kids and I decided I could not continue to put off building my dream car. While I had always wanted an original 914/6, I also wanted a general purpose fun car (Street, Autocross and Track) that would have had more power and safety features than a stock 914/6. I can't afford to have multiple 914s (a stock 914/4, a 914/4 with a modern Type IV, a stock 914/6, a 914/6 GT Clone, a track only 914, etc.), so rather than molest a "real" 914/6 to build my dream "six", I decided to start with a regular 914/4 and do a six swap. This car was purchased in 8/2005. Over the past two years I have disassembled the entire car and am now at the point of doing repair and refurbishment. Which is why I picked now as the time to do the progress thread (who wants to read about the dis-assembly of a car!) Goals for the car...
I have my own website that contains a higher level of detail on specific sections of the car as well as a more detailed general Blog. I currently host this at home and sometimes the server is down, but it is up most of the time. You can find that here... http://motorsport.zyyz.com/project_914.htm |
John |
Jan 2 2008, 12:34 PM
It looks like you are making good progress with your project.
I have a few questions: What are you using to media blast? What protective gear do you need? How much of a mess does it make? How much of the media are you able to recover? I am assuming that you are doing this in an open space in your garage. |
Richard Casto |
Jan 2 2008, 02:10 PM
It looks like you are making good progress with your project. I have a few questions: What are you using to media blast? What protective gear do you need? How much of a mess does it make? How much of the media are you able to recover? I am assuming that you are doing this in an open space in your garage. Blaster: 40lb pressure pot from HF. I generally like it so far. This is my first pressure pot blaster. I think to make it work right, you have to screen/filter your media, don’t go crazy with the pressure (generally been using 30-60 psi), get a good ratio of air vs. media and then work on your technique. This is what I am using… http://www.harborfreight.com/cpi/ctaf/disp...temnumber=34202 Media: Coal slag 30/60 grit in the areas with rust. I am probably going to use paint stripper as much as I can on the panels and then media blast what that doesn’t remove. I may try some aluminum oxide on the panels as well, but so far I like the coal slag (Black Diamond and Black Beauty are common brand names of Coal slag). Gear: The protective mask/hood that came with the blaster, leather gloves and respirator. You will require a good shower when you are done as you will have dust and grit in everything. Mess: I built a tent (PVC pipe and 6 mil plastic) in the garage to keep the mess down. When not blasting, I roll the sides of the tent up and tie them in place. I used 6 mil plastic because that is what I had around, but I think it is overly heavy and at some point I am going to replace this with lighter plastic. I probably will also re-engineer some of it to make it a bit higher, but toward the door of the garage I can only make it so high as I like to be able to open/close my garage door. This entire thing will be converted to my paint booth in the future (will need to clean it all up, new plastic, etc.). If you keep the area pretty clear it is pretty easy to sweep up the media and reuse. In addition to what is in the pressure pot, I have a clean 5 gallon bucket and as I sweep up the media, I filter it and put it back into the bucket. I bought two 50 lbs bags of media and I am guessing that while I have cycled it through a number of times, I probably still have 80% of it left. Here is a picture of the tent… |
Lo-Fi Version | Time is now: 28th April 2024 - 05:52 PM |
