| slackin' at work |
Nov 1 2007, 12:46 PM
i should be working ![]() ![]() Group: Members Posts: 265 Joined: 12-October 07 From: charlottesville, va Member No.: 8,215 Region Association: MidAtlantic Region |
Ok, my old 74 had this but it was LOW and I never installed a bumpsteer kit.
however, my new 72 in pretty close to stock height, perhaps a tad lower. so anyway, when Im taking a corner on a bumpy road, the steering wheel moves back and forth in my hand. However, the car stays on track and doesn't wander (my previous understanding of bumpsteer). is this bumpsteer or normal?? I wasn't expecting it with the new car, but there it was. if not 'bumpsteer' what is it. thanks in advance everyone. -chris |
| Brian_Boss |
Nov 1 2007, 09:28 PM
Member ![]() ![]() Group: Members Posts: 324 Joined: 3-June 03 From: Dallas, TX Member No.: 781 |
Since none of the chassis gurus have jumped on this, I will take a crack at at it. At least it will give you a "bump" (IMG:style_emoticons/default/wink.gif) to the top of the page.
IME, bump steer is most noticeable on a smooth but undulating high speed bend. Unless the geometry is really out of whack, you will just feel the front end grip change as the front suspension compresses and rebounds. No violent motion of the steering wheel. In a corner with a lot of little bumps, like a washboard surface, a stiffly sprung car will tend to lose grip and sort of "skitter" sideways as the car gains and loses grip, both front and rear. The car actually takes little sideways hops. This has nothing to do with real bump steer. This will tend to make the steering wheel move. Hope this helps. BB |
| messix |
Nov 2 2007, 12:10 AM
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
bumpsteer is actually a geometric problem with the the steering and suspension links. it causes the wheels to increase or decrease in steering angles as the suspension moves thru it's travel.
this can be measured with the wheels pointed straight and cycling the wheel thru its travel. you can "feel the the road" thru the steering wheel and as you hit bumps, rocks and such you should feel some feel in the steering but not like it's going to come out of your hands. worn bushings, rod ends and ball joints can cause the steering wheel to get twitchy, and might be what your describing. |
| slackin' at work |
Nov 2 2007, 08:36 AM
thanks guys.
"Twitchy" is an excellent description. I don't need to correct any during the corner, the wheel is just a little twitchy. nothing too pressing... but just wanted to double check with you guys with more experince in the teener-world. (IMG:style_emoticons/default/beer.gif) |
| Rand |
Nov 2 2007, 02:04 PM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
| craig downs |
Nov 2 2007, 08:36 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 769 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
Sounds like your tires are out of balance if your steering wheel is shaking. If it was
bump steer your car can change direction suddenly when you hit a bump. |
Lo-Fi Version | Time is now: 13th February 2026 - 07:34 AM |
