Am I missing something?, 76 Fuel line woes |
BiG bOgGs |
Nov 3 2007, 02:21 PM
The Bogus One Group: Members Posts: 452 Joined: 25-September 04 From: Ft. Myers, FL 33967 Member No.: 2,829 Region Association: South East States |
When I checkout fuel line diagrams, I always see that both fuel rails are depicted the same. 5 ports on each rail. 2 injector ports, 1 inlet port, 1 outlet port, and then the one side has a fitting for a pressure meter in the middle of the rail, and the other sied has a port that goes to the cold start valve. Here is a picture of what I have.
I don't remember how the lines were previously routed, but as far as I can figure, the PO didn't have the cold start valve connected, or he was using the guage connection point to run to the cold start valve. But if he was routing it the second way, why do I have the screw and washer that block off the pressure guage connection point? Please educamcate me lads! Jim |
Lo-Fi Version | Time is now: 19th May 2024 - 02:07 AM |
