14 inch track tires, Driver's Ed |
MikeSpraggi |
Nov 5 2007, 06:08 PM
Senior Member Group: Members Posts: 781 Joined: 7-February 05 From: Silver Spring, Md Member No.: 3,570 Region Association: MidAtlantic Region |
I just bought an original 914/6 that came with 14" Fuchs. Those that are running 14" rims, what type of tires are you using for Driver's Ed. Are the Falken Azenis RT-615 good for this purpose?
Van914 |
Nov 5 2007, 06:52 PM
Van914 Group: Members Posts: 698 Joined: 5-January 03 From: Cincinnati, Ohio Member No.: 90 Region Association: Upper MidWest |
I just bought an original 914/6 that came with 14" Fuchs. Those that are running 14" rims, what type of tires are you using for Driver's Ed. Are the Falken Azenis RT-615 good for this purpose? Mike, You should be looking for 15" wheels. I am using Victo Racers now but I am going to Toyo R1's in 205X50X15. Van914 |
jd74914 |
Nov 5 2007, 11:36 PM
Hi Mike,
Hope life's been treating you well :wave: You have to put up some pictures of your new /6. The 2.2E we bought from you is still sitting unused . . . we're just way too busy to rebuild it. On subject, there really isn't a great selection of tires in the 14in sizes. As Van said you probably are better getting some 15in track wheels. Unless you are going to slicks the Falkens might be the best tire in that diameter. Jim |
smokey |
Nov 7 2007, 05:04 AM
Senior Member Group: Members Posts: 533 Joined: 15-June 07 From: Freedom Ca Member No.: 7,816 Region Association: None |
205/55/zr14 hoosier race . tread pattern is M . it is a dot tire that can be run on the street . pricy . and sticky . i am running them (IMG:style_emoticons/default/smoke.gif)
MikeSpraggi |
Nov 7 2007, 01:21 PM
Hi Mike, Hope life's been treating you well :wave: You have to put up some pictures of your new /6. The 2.2E we bought from you is still sitting unused . . . we're just way too busy to rebuild it. On subject, there really isn't a great selection of tires in the 14in sizes. As Van said you probably are better getting some 15in track wheels. Unless you are going to slicks the Falkens might be the best tire in that diameter. Jim Jim, glad to hear you're still around. I love my 914/4 2.0L but I had an opportunity to buy the /6 at a really good price ... so I did. As you know, my garage will only hold 2 teeners nose to tail and with the track car I'm building and the /6 as keepers, the /4 has to go. I wouldn't subject any 914 to the elements, and the /4 has really been good to me ..... life can be harsh! (IMG:style_emoticons/default/smile.gif) Mike |
smokey |
Nov 14 2007, 05:08 AM
anyone know of any other tires ?
smokey |
Nov 15 2007, 01:20 PM
(IMG:style_emoticons/default/hide.gif) (IMG:style_emoticons/default/birthday3.gif) (IMG:style_emoticons/default/wreath.gif) (IMG:style_emoticons/default/red914.jpg) (IMG:style_emoticons/default/white914.jpg) (IMG:style_emoticons/default/blue914.jpg)
MikeSpraggi |
Nov 16 2007, 02:18 AM
(IMG:style_emoticons/default/hide.gif) (IMG:style_emoticons/default/birthday3.gif) (IMG:style_emoticons/default/wreath.gif) (IMG:style_emoticons/default/red914.jpg) (IMG:style_emoticons/default/white914.jpg) (IMG:style_emoticons/default/blue914.jpg) What kind of wheels are you running those fat boys on? You got flares? |
smokey |
Nov 16 2007, 07:05 AM
no flares . 5.5x14 . stock five lug fuches . 3.2 dme . limited slip . patrick motorsports everything .
Chris Pincetich |
Nov 16 2007, 09:39 PM
All those brits run <15 inch wheels and tires so it can't be too bad, even some fast miatas I think. Those rims are sweet, I wish I had the 5 lug hubs sometimes. (IMG:style_emoticons/default/beerchug.gif)
So smokey - are you going to drive on hwy 9 with those tires? (IMG:style_emoticons/default/huh.gif) |
smokey |
Nov 16 2007, 10:15 PM
YOKAHAMA AO48 205/55r15 tread were 90 very fun on H 9 . they are now on 15x5.5 fuchs . the slicks are for time trial / auto X . (IMG:style_emoticons/default/smoke.gif)
betegh9 |
Nov 23 2007, 02:35 PM
Newbie Group: Members Posts: 11 Joined: 27-September 07 From: Blue Bell, Pa. Member No.: 8,165 |
If you are new to AX, run your present tires till you chord them......... great to learn on. Then, if you like to drive on an R rated tire at ALL times and not bother with another set of wheels, then get Toyo RA-1's. If you want a dedicated AX tire, and you have reached the limits of the car and the RA-1's, buy Kumho V710's or pricier Hoosier A6's. The hoosiers will probably give you about 7 AX events for about $1000.00, can you handle that?............. not me!! (IMG:style_emoticons/default/driving.gif)
i love porsche |
Nov 27 2007, 11:16 AM
Senior Member Group: Members Posts: 1,547 Joined: 6-May 04 From: Nutley, NJ Member No.: 2,030 Region Association: North East States |
theres a clearance right now on kumho ecsta v700s on tire rack..they come in 14 sizes..check them out
Lo-Fi Version | Time is now: 7th May 2024 - 09:19 AM |
