> running stock distributor with carbs., another question from me....
slackin' at work
post Nov 8 2007, 02:37 PM
i should be working
my car has a 009 and I know it is not doing me any favors.
I NEED to replace it with something... and Im eventually going back to FI.
so my question is, can I run a stock distributor with dual carbs? Should I take the trigger-points out until Im ready to go FI?
of course I don't have the stock distributor, so before I buy one Id like to know if it's OK to run it until I make the swap.
(IMG:style_emoticons/default/beer.gif)
-chris
TravisNeff
post Nov 8 2007, 02:48 PM
yes you can run a stock distributor, I'd leave the trigger points in as you will get a bunch of crap in your distributor from the hole where the points were. Rig up a retard line in your intake manifold too.
anderssj
post Nov 8 2007, 02:49 PM
Dog is my copilot...
I've heard that the stock distributor from a 1.8L is a good choice, but I have no personal experience (still running a bosch 050 with DRLA40s).
Best,
slackin' at work
post Nov 8 2007, 03:53 PM
i should be working
thanks guys for the thoughts.
I was just about to buy an SVDA dist. from aircooled.net (I was at the online checkout) and realized it was dumb if I was just going to have to find a stock one once I went to make the swap.
(IMG:style_emoticons/default/teef.gif)
andys
post Nov 8 2007, 04:38 PM
When I made a Weber carb swap on my 2.0L some 30+ years ago, I used the stock distributor.
Andys
914Mike
post Nov 8 2007, 07:23 PM
QUOTE(anderssj @ Nov 8 2007, 12:49 PM) *
Best,
Yep, the one from almost any 1.8 is mo' better than any 009! (IMG:style_emoticons/default/barf.gif) (Or the one from a 2.0 bus motor for that matter. ) I'm running the 1.8 dizzy on my 2056 with the baby Webers, set the max advance @ 27 deg. and it's good to go, nice idle 'cause the mechanical advance has lots more degrees than a 009. I never hooked up the retard side of the dashpot, but the advance side is connected to the Weber vac ports... (IMG:style_emoticons/default/beer.gif)
BarberDave
post Nov 9 2007, 05:20 AM
Barberdave
I use a 50 with a Petronics (sp) unit, with 40's since 2000 ,the only trouble was
of my own makeing. I.E. left the ignition switch on burnt the Petronics out.
Good luck Dave (IMG:style_emoticons/default/slap.gif)
- Lo-Fi Version Time is now: 13th February 2026 - 08:13 AM
