FS/76 Dressed in black 914-6 / 2.2-6 / webers, Yes its fast .. & ...yes its sold ! |
GT40-914r |
Nov 9 2007, 01:05 AM
Newbie Group: Members Posts: 17 Joined: 26-June 05 From: sanbernardino so. cal. Member No.: 4,331 |
FS /-fresh 1976 914-6 conversion ...Dressed in black
Okay ! here you go Sold /Sold/Sold ---------- Destination : United Kingdom (IMG:style_emoticons/default/smilie_pokal.gif) To a Great Fellow 914-6 rrrr Cheers ..to Kevin (IMG:style_emoticons/default/welcome.png) And a grip of thanks to all you fellow 914rrrs that have given me great advice and support !!!! Now ! ...onto my 914-8 Based 914-GT-40 MK1 project ... (IMG:style_emoticons/default/welder.gif) NEW digital pictures were just added check out pages 4 and 5 new digi shots ... this is a great loss to me ... and your gain !!!! shippings services available ..anywhere in the US and Canada and UK Very sweet ..Tight street or event car ...Chassis # NR 5039049 -Title #4762904071 Porsche-6 cyl- 2.2 Has a fresh rebuild with test and tune miles only Restoration and conversion -3 years Weber triples - 40 IDA Webers - tight throttle shafts Screened velocity stacks PowerPlant 69 2.0 magnesium Block / `bottom end -case #6290505 with 2.2 heads # K1819d / 7-1967 / 8-1967 /901-104-306.OB valves 38x42mm Bore 83.98 @ 2.2 Webb S cams New style Hydraulic Tenssioners have been installed New German PP / new pilot bearing New Stage 1 Clutch disc 911-header/exhaust system ... produces good mid range performance and Hirevving tourque curve ...wonderful song 914-6 conversion has less than -50- miles since car and engine were completed Jan 07 original California car ...with fresh simple updates .... I have found a small amounts of "surface rust" in the normal areas....No Holes were found longitudinals were fine and New chassis undercoating everywhere Pan has a few bottoming indents ..nothing to get twisted about pics of any area available ....on request New High capacity racing-11.5 qt aluminum oil tank with high flow oil cooler installed fully aero quipped .. with #12 A&N .SS high pressure lines were installed Billet anodized New Hamberger-dual high volume alum billlit sysfr- with dual FR-1 racing filters New Hi flow oil cooler fully 12 A&N Aero quipped SS New HP- SS braided .oil lines 911-wrapped headers with baffled stingers New Battery Givani Racing Rims - 17x7s + 40mm offsets Tires 205-40-17 s (summer compounds) New jet black paint (Stripped to metal / epoxy base primed ) very proffesionaly done NEW Complete custom interior / deep ferrari red / Pitch Black New Plush -Black Carpets New APC racing seats - comfortable JVC / New 350 watt Stereo system /12"Vega sub wfr / 2 5x7s / 2 HGs big thumpin sound ..nice New light wght fully adjustable Aluminum rear wing Light wght doors Light wght early- front and rear bumpers included front & rear sway bars - solid ball joints -solid New rear drop link .urethanes New Super Comp - Carbon Fibre Face Tach w/ external redline Light center console - working clock short shifter New cutch cable New throttle cable New Facet electric pump New CVs and rubber boots -4 New trans fluid change Used spare set of light wght glass bumpers ( early style ) New Dash cover Special front & rear glass Tints - chrome to black New Led -Modem style side view mirrors Rear Louvered engine lid .for better air flow New Chrome engine lid Grill Targa Top Refinished in black epoxy - to match car targa top - fits in trunk as needed New rear Brake proportioning valve New rear brake lines and flex lines good luck .. (IMG:style_emoticons/default/smilie_pokal.gif) Sir Lawrence Attached image(s) |
pcarrell |
Nov 9 2007, 11:38 AM
Newbie Group: Members Posts: 6 Joined: 15-October 07 From: Indianapolis, Indiana Member No.: 8,231 Region Association: None |
stateofidleness |
Nov 9 2007, 11:57 AM
Senior Member Group: Members Posts: 810 Joined: 1-September 07 From: Canyon Lake, Texas! Member No.: 8,065 Region Association: None |
thats a sexy car
what rims are those? |
GT40-914r |
Nov 9 2007, 01:18 PM
Rims are " Giavani " 17x7s -40mm offset 4x114.3 mm bolt pattern ... hard to find and rare ..however there are several new wheels that are available which are very similar ....they really do look slick ..haa !
a set of 6061 billet adapters to convert ...and a little love on the rear wheel well lips of your 914 .... they fit well on the " stock "914 Attached image(s) |
stateofidleness |
Nov 9 2007, 03:45 PM
chalon kit. no lovin necessary (IMG:style_emoticons/default/wink.gif)
they really do look nice, kind of leary of adapters though. gl on the sale. |
Gint |
Nov 9 2007, 05:58 PM
Mike Ginter Group: Admin Posts: 16,075 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Pretty nice. Is it a factory black car? I realize repaint, etc... but was it originally black?
al z |
Nov 9 2007, 09:16 PM
I'm new here ... Group: Members Posts: 0 Joined: 3-August 07 From: michigan Member No.: 7,968 |
GT40-914R PM sent. Thanks in advance..AL Z
GT40-914r |
Nov 10 2007, 12:02 AM
Pretty nice. Is it a factory black car? I realize repaint, etc... but was it originally black? epoxy primered than epoxy pitch black .. (IMG:style_emoticons/default/smilie_pokal.gif) Attached image(s) |
914sBaby! |
Nov 10 2007, 01:41 AM
Newbie Group: Members Posts: 29 Joined: 26-December 06 From: Studio City, CA Member No.: 7,381 |
Isn't this car a '76? Add says '71. Which one is it? Thanks!
GT40-914r |
Nov 10 2007, 02:07 PM
Isn't this car a '76? Add says '71. Which one is it? Thanks! My apologies ..This is a "76 " with 71 light wght doors .71 fibreglass light weight bumpers to be included in the sale .....and a 71 2.2 911 engine etc .. linspected by dmv tagged & titled in so. cal riddle: 76 .must be smogged in so cal ...71 no smog needed 76 tub / 76 side shifter trans ...rust free tub .. (IMG:style_emoticons/default/agree.gif) Yes its Mine ... yes its Legal ... yes you can DRIVE IT ! best regards good luck L (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/welder.gif) Attached image(s) |
porschecb |
Nov 10 2007, 04:08 PM
Senior Member Group: Members Posts: 1,092 Joined: 13-August 04 From: Las Vegas NV Member No.: 2,529 Region Association: None |
This is one amusing post to say the least! Makes me wonder if you really want to sell the car or be somewhat of a smart ass! So lets answer questions with riddles? (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/sheeplove.gif) (IMG:style_emoticons/default/slap.gif)
Eric_Shea |
Nov 10 2007, 04:38 PM
I think you guys have to know Lawrence to get the humor... probably not fair to call him a smartass.
I beleive what he's trying to say is: This is a 76 car that, while residing in the great state of Kalipornia "somehow" became titled as a 71 car. It does come with 76 paperwork. Make sense? |
GT40-914r |
Nov 10 2007, 04:54 PM
This is one amusing post to say the least! Makes me wonder if you really want to sell the car (IMG:style_emoticons/default/aktion035.gif) Im cool with that .. dont need to sell this 914-6 just thinning the Herd ! havin fun ... I think ! apologies ... let me know if you have any questions this is a very sweet 914-6 for sale ..looking for serious offers make an offer I cant refuse ... jump in your 914 and meet me for a brew (IMG:style_emoticons/default/driving.gif) best regards Sir Lawrence a few reasons to sell the 914-6 74 vintage RCA formula -vee 66 GT-40 / 289 ( gulf) rep project 69 cal bug 71/76 914-6 91 suzuki GT twin cammer 91 HD buell 1200xlh 93 cobra GT 5.0 convertible 94 33" holiday imperial MTR HM 78 25ft seidleman -sloop Bunch of giant scale rc airplanes ..and this computer ... all for sale or trade for a liver transplant ... (IMG:style_emoticons/default/pray.gif) Attached image(s) |
GT40-914r |
Nov 10 2007, 05:01 PM
I think you guys have to know Lawrence to get the humor... probably not fair to call him a smartass. I beleive what he's trying to say is: This is a 76 car that, while residing in the great state of Kalipornia "somehow" became titled as a 71 car. It does come with 76 paperwork. (IMG:style_emoticons/default/type.gif) Make sense? Thanks E ..I needed that ...100% thanx (IMG:style_emoticons/default/smilie_pokal.gif) SL Attached image(s) |
914sBaby! |
Nov 10 2007, 08:29 PM
ANY RUST? ANY? When can I see the car? Thanks!
GT40-914r |
Nov 10 2007, 09:39 PM
ANY RUST? ANY? When can I see the car? Thanks! Ssmall areas of surface rust existed passenger side longitudinal ( hell hole area ) showed surface rust "No rust holes" I rienforced any areas of potential future rust problems the battery box was replaced with a heavier gauge unit the longitudinal was plated with reinforcement pcs and welded to add strength Since the pas side longitudinal showed the beginnings of future rust concerns ... the entire area was reinforced with 16 ga plates.. I spanned the plates well into clean areas ..migged into place 14-16ga plated the upper/ inner side of the frame / longitudinal for extra strength .. all seams were Mig Welded into place all along Reinforcements contiuous bead welds .. were used primed painted and undercoated the entire chassis trunk.tail light area had a small surface rust ..cleaned up nice treated /primed / undercoated all potential rust areas were treated and undercoated in and out ... weather it needed it or not request pictures of any area ..I will send them to you or you may inspect them yourself .....you seem to be about an hour from me here in Sanbernadino contact me on my cell for appt time cell #909-717-5260 best regards SirLawrence (IMG:style_emoticons/default/icon_bump.gif) Attached image(s) |
GT40-914r |
Nov 11 2007, 12:14 AM
(IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/smilie_pokal.gif)
Gint |
Nov 17 2007, 11:23 PM
GT40-914r |
Nov 17 2007, 11:28 PM
$? Attached image(s) |
GT40-914r |
Nov 17 2007, 11:31 PM
Lo-Fi Version | Time is now: 23rd May 2024 - 12:32 PM |
