FS /-fresh 1976 914-6 conversion ...Dressed in black
Okay ! here you go Sold /Sold/Sold
Destination : United Kingdom
To a Great Fellow 914-6 rrrr
Cheers ..to Kevin
And a grip of thanks to all you fellow 914rrrs
that have given me great advice and support !!!!
Now ! ...onto my 914-8 Based
914-GT-40 MK1 project ...
NEW digital pictures were just added
check out pages 4 and 5
new digi shots ...
this is a great loss to me ... and your gain !!!!
shippings services available ..anywhere in the US and Canada and UK
Very sweet ..Tight street or event car ...Chassis #
NR 5039049 -Title #4762904071
Porsche-6 cyl- 2.2 Has a fresh rebuild with test and tune miles only
Restoration and conversion -3 years
Weber triples - 40 IDA Webers - tight throttle shafts
Screened velocity stacks
PowerPlant
69 2.0 magnesium Block / `bottom end -case #6290505 with
2.2 heads # K1819d / 7-1967 / 8-1967 /901-104-306.OB
valves 38x42mm
Bore 83.98 @ 2.2
Webb S cams
New style Hydraulic Tenssioners have been installed
New German PP / new pilot bearing
New Stage 1 Clutch disc
911-header/exhaust system ...
produces good mid range performance and Hirevving tourque curve ...wonderful song
914-6 conversion has less than -50- miles since car and engine were completed Jan 07
original California car ...with fresh simple updates ....
I have found a small amounts of "surface rust" in the normal areas....No Holes were found
longitudinals were fine and
New chassis undercoating everywhere
Pan has a few bottoming indents ..nothing to get twisted about
pics of any area available ....on request
New High capacity racing-11.5 qt aluminum oil tank with high flow oil cooler installed
fully aero quipped .. with #12 A&N .SS high pressure lines were installed
Billet anodized New Hamberger-dual high volume alum billlit sysfr- with dual FR-1 racing filters
New Hi flow oil cooler fully 12 A&N Aero quipped SS
New HP- SS braided .oil lines
911-wrapped headers with baffled stingers
New Battery
Givani Racing Rims - 17x7s + 40mm offsets
Tires 205-40-17 s (summer compounds)
New jet black paint (Stripped to metal / epoxy base primed ) very proffesionaly done
NEW Complete custom interior / deep ferrari red / Pitch Black
New Plush -Black Carpets
New APC racing seats - comfortable
JVC / New 350 watt Stereo system /12"Vega sub wfr / 2 5x7s / 2 HGs big thumpin sound ..nice
New light wght fully adjustable Aluminum rear wing
Light wght doors
Light wght early- front and rear bumpers included
front & rear sway bars - solid
ball joints -solid
New rear drop link .urethanes
New Super Comp - Carbon Fibre Face Tach w/ external redline Light
center console - working clock
short shifter
New cutch cable
New throttle cable
New Facet electric pump
New CVs and rubber boots -4
New trans fluid change
Used spare set of light wght glass bumpers ( early style )
New Dash cover
Special front & rear glass Tints - chrome to black
New Led -Modem style side view mirrors
Rear Louvered engine lid .for better air flow
New Chrome engine lid Grill
Targa Top Refinished in black epoxy - to match car
targa top - fits in trunk as needed
New rear Brake proportioning valve
New rear brake lines and flex lines
good luck ..
Sir Lawrence
