high-torque starters, good or bad? |
SGB |
Nov 10 2007, 02:22 PM
Well, I can tell ANOTHER starter is failing. There was great enthusiasm for those gear reduction starters available on ebay - for a while. Then the reports started coming in about possible problems. I think I remember that they were damaging flywheels or something. What has your experience been if you have one of these?
McMark |
Nov 10 2007, 02:27 PM
My experience is that some of the models don't retract far enough and will hit the flywheel ring gear teeth. I have one in my car that did that. But I noticed the odd noise the first time I tried to start it. Pulled the starter back out and spaced the starter away from the transmission with a washers on each of the mounting bolts. The Cap'n says I'm a fool to do it that way, and I don't disagree with him in theory (the immense torque can/will rock the starter if it's not fully supported). But I'm willing to deal with it. Maybe it's worth talking to Engman about cutting a Hi-Torque Spacer that would more suitably support the starter.
okieflyr |
Nov 10 2007, 10:49 PM
9fauxteen Group: Members Posts: 816 Joined: 9-January 05 From: Phila PA Member No.: 3,426 Region Association: North East States |
Mine has served me well for almost 2 years now. I expect to pull it soon and sell it, as I'm working on another transmission type and won't need it. At that time i'll look at the ring and see if there are any ongoing issues....
Well, I can tell ANOTHER starter is failing. There was great enthusiasm for those gear reduction starters available on ebay - for a while. Then the reports started coming in about possible problems. I think I remember that they were damaging flywheels or something. What has your experience been if you have one of these? |
SLITS |
Nov 11 2007, 12:16 AM
My experience is that some of the models don't retract far enough and will hit the flywheel ring gear teeth. I have one in my car that did that. But I noticed the odd noise the first time I tried to start it. Pulled the starter back out and spaced the starter away from the transmission with a washers on each of the mounting bolts. The Cap'n says I'm a fool to do it that way, and I don't disagree with him in theory (the immense torque can/will rock the starter if it's not fully supported). But I'm willing to deal with it. Maybe it's worth talking to Engman about cutting a Hi-Torque Spacer that would more suitably support the starter. If you spend a few more bucks and by the good one from RB Performance, Parker, Arizona, you won't have the problems. His are about $170ish. |
Gary |
Nov 11 2007, 12:39 AM
Senior Member Group: Members Posts: 744 Joined: 12-January 03 From: Mount Airy, MD Member No.: 134 Region Association: MidAtlantic Region |
Got mine a couple years ago from Pelican. Turns the 2.7 fine. It's smaller, lighter too (IMG:style_emoticons/default/smile.gif).
Air_Cooled_Nut |
Nov 11 2007, 05:38 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
While mine works well (e-bay unit), it required a thin spacer to move it away a little bit as it was engaging too far into the flywheel. Yeah, a washer under the bolts will work. I used a full-face spacer I made in leu of washers.
Root_Werks |
Nov 11 2007, 06:13 PM
Village Idiot Group: Members Posts: 8,321 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
They'll knock the teeth right off of aluminum flywheels.
jd74914 |
Nov 11 2007, 07:07 PM
Where do you get a totally Al flywheel?
Twystd1 |
Nov 11 2007, 07:42 PM
For that matter.... Aluminum ring gears..???
Muy no comprende. C |
PRS914-6 |
Nov 11 2007, 08:34 PM
See this thread.
I have bought 2 starters from Highperformnance USA. One for my 3.6 and the other for a 383 high compression Chevy in my truck. No problems with either. No goofy noises when cranking, no spacers or washers. Bolt in and go...... |
jd74914 |
Nov 11 2007, 08:37 PM
type47fan |
Nov 11 2007, 09:53 PM
It Looks Better In Person. . . Group: Members Posts: 860 Joined: 17-September 03 From: Carlsbad, CA Member No.: 1,170 Region Association: Southern California |
While mine works well (e-bay unit), it required a thin spacer to move it away a little bit as it was engaging too far into the flywheel. Yeah, a washer under the bolts will work. I used a full-face spacer I made in leu of washers. Full face spacer thickness? Gotta picture? Thanks, |
SGB |
Nov 12 2007, 12:09 AM
The washer idea, while expedient, does seem scary. The load transferred to the bolt holes during engagement has got to be quite an impact. I would have to go for one that is the proper throw, or a full spacer to take some of that impact and transfer it to the mounting area, not just the bolts and holes.
IronHillRestorations |
Nov 12 2007, 11:09 AM
OEM Bosch starters have little to zero problems.
Do ya feel lucky? Do ya have AA? Do you like to buy starters and/or flywheels? Can you guess my .02 on this issue?? |
wbergtho |
Nov 12 2007, 07:13 PM
Senior Member Group: Members Posts: 1,314 Joined: 28-April 03 From: Roberts, WI Member No.: 623 |
QUOTE No goofy noises when cranking, no spacers or washers. Bolt in and go...... I have the E-Bay starter and it turns over my 11.3:1 LS6 V-8 just fine. Mine bolted right to my 930 box without spacers or any issues. |
Dr Evil |
Nov 12 2007, 07:50 PM
The ebay one I got works very well, but there are other types that do not work well and cause the aforementioned problems. Do a search and you will see.
KaptKaos |
Nov 12 2007, 09:04 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
I got the ebay one too and it has worked well for me.
At one point, the starter had a problem. The guy I bought it from cleaned it up and sent it back, no problem. Turned out to be the beginning symptoms of my tranny leak, as fluid was getting inside the starter. |
echocanyons |
Nov 12 2007, 09:21 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
My 6mo experience with an ebay hi-torque mini.
It spins quick but often doesn't retract quickly enough and drags. It is finicky, I mean sometime it just doesn't work. I thought that it was my electrical ignition switch but after I replaced the switch the problem persists, I now know that it is the starter. I thought it was a reasonable upgrade/alternative to the original, but I soon will be replacing it with an oem replacement type. I have it spaced out with 3 washers of unknown thickness. I haven't recently seen the shape of my flywheel but I do know that a rebuilt bosch is cheaper than a new flywheel. On the other hand it is definitely much lighter and smaller. |
Root_Werks |
Nov 12 2007, 09:47 PM
Patrick MotorSports makes full aluminum flywheels that look like swiss cheese and weigh pretty much nothing. I have installed 3 in my life, one of them because I got the timing just a tad off on fire up, while cranking over on the engine with a high torque starter. Ripped the teeth right off the unit.
Project 6 |
Nov 12 2007, 10:10 PM
large member Group: Members Posts: 359 Joined: 30-December 02 From: Utah Member No.: 51 Region Association: None |
OEM Bosch starters have little to zero problems. Do ya feel lucky? Do ya have AA? Do you like to buy starters and/or flywheels? Can you guess my .02 on this issue?? I agree BUT, Bosch doesn't make new ones and they don't do the rebuilds. The rebuilds are only as good as the rebuilder. That's why I keep cores, send them to a local rebuilder so that I can be assured of quality. I also prefer the SR68X model which is 1.5hp. |
Lo-Fi Version | Time is now: 19th May 2024 - 04:59 AM |
