Crankcase breather with carbs., How do you attach a hose to the filters? |
Thack |
Nov 11 2007, 11:32 PM
Member Group: Members Posts: 283 Joined: 1-June 05 From: Houston, Tx Member No.: 4,182 |
For those running dual carbs, how do you attach a crankcase breather hose to the filters? Especially if you have K&Ns, which I plan to replace. Do you run two hoses? Got pics? (IMG:style_emoticons/default/sawzall-smiley.gif)
So.Cal.914 |
Nov 11 2007, 11:59 PM
For those running dual carbs, how do you attach a crankcase breather hose to the filters? Especially if you have K&Ns, which I plan to replace. Do you run two hoses? Got pics? (IMG:style_emoticons/default/sawzall-smiley.gif) My K&N's had KO's on the bottom, knock them out and put in nipples. I have seen some useing one hose to one filter with a 'Y' to bring in both sides and tieing the oil filler breather into one of those. I didn't like that idea. |
pete914 |
Mar 4 2008, 06:32 AM
Member Group: Members Posts: 178 Joined: 21-August 07 From: east coast Member No.: 8,025 |
hijacking the thread here...pics anyone?
SGB |
Mar 4 2008, 07:06 AM
I wouldliketo see this too. I don't think I have any knock out plugs under there...
Joe Ricard |
Mar 4 2008, 07:44 AM
It's easy.
YOU DON'T. Get a CB or EMPI breather box or for a real breather system one from JEGS or SUMMIT Puke can. |
pete914 |
Mar 4 2008, 08:58 AM
Joe Ricard |
Mar 4 2008, 09:15 AM
Why?
All you are doing is sucking oil into the carbs. real good way to clogg them up with gunky oil film. Run the valve cover vents to the box and the oil filler PCV to the box and let the box breath through the cover as desiged. |
rhodyguy |
Mar 4 2008, 09:20 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,072 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
or...with 2.0 heads with the drain/vapor return tubes, you run a single vent line from the oil fill tower to the cb style foam filled box and lines from the outlets on the box to the heads. you need to ensure the bb is mounted high enough for the oil to flow to the heads and not puddle in the lines. with the cb bb, squeezing the dirty oil out of the foam filter and soaking up the small ammount in the bottom should be considered part of routine maintenance.
k |
pete914 |
Mar 4 2008, 10:56 AM
Do I need the valve covers to be vented? Right now they aren't. Would the oil filler PCV valve into the box be sufficient? Might just run a tube from the box to the underside of the car. Hate to put more fumes in the air though...as if dual webers aren't bad enough...
Why? All you are doing is sucking oil into the carbs. real good way to clogg them up with gunky oil film. Run the valve cover vents to the box and the oil filler PCV to the box and let the box breath through the cover as desiged. |
rhodyguy |
Mar 4 2008, 11:34 AM
just venting to the underside of the car is not the way to go, imho. the tubes i mentioned return to the valve cover area, so venting to the valve covers is a better idea. drill a couple of holes in the engine tin and run the lines thru grommets.
Joe Ricard |
Mar 4 2008, 11:39 AM
Word. DO NOT vent it under the car. You will end up draining the entire sump Via vapor and depositing it on the under side of your motor.
Mar 4 2008, 11:57 AM
Resident German Group: Admin Posts: 41,618 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Word. DO NOT vent it under the car. You will end up draining the entire sump Via vapor and depositing it on the under side of your motor. (IMG:style_emoticons/default/agree.gif) the vent needs to be higher than the motor ... (IMG:style_emoticons/default/shades.gif) Andy PS: here's a pic of my CB setup i had on the old 2056 ... the head-vents actually suck in air at higher rpms, so any oil that puddles up in the breather box just runs back into the heads ... Attached image(s) |
akellym |
Mar 4 2008, 11:59 AM
Eyes Of The Deep Battle Group: Members Posts: 597 Joined: 25-July 04 From: Annandale, MN Member No.: 2,395 Region Association: Northstar Region |
this works very well for me.
pete914 |
Mar 4 2008, 03:14 PM
sirandy,
so you have one line from oil filler to puke box...two lines from puke box to each valve cover? what kind of fastener grommets are you guys using? it would be so, so, so bad if that came loose in there. further, must have to be a tight fit to keep the dirt out... thanks for your help. just want to do this right the first time... by the way...very nice looking engine bay akellym |
Mar 4 2008, 04:05 PM
sirandy, so you have one line from oil filler to puke box...two lines from puke box to each valve cover? what kind of fastener grommets are you guys using? it would be so, so, so bad if that came loose in there. further, must have to be a tight fit to keep the dirt out... almost ... oil filler to puke box ... stock head vents to puke box ... no need to mess with the valve covers if you have heads that have the stock vent setup. i forget which years had the head vents (IMG:style_emoticons/default/shades.gif) Andy green arrow points to the vent hole. it has a insert that you simply clamp the hose to ... Attached image(s) |
orange914 |
Mar 4 2008, 04:26 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
pete914 |
Mar 4 2008, 05:51 PM
anyone know the stock years they had the vents? I'm running a '74 1.8L
chris914 |
Mar 4 2008, 06:52 PM
Member Group: Members Posts: 489 Joined: 24-July 04 From: San Diego, CA Member No.: 2,393 Region Association: Southern California |
Does anyone have pictures of how they added them to the valve covers? My 2 liter heads do not have the breather ports.
So.Cal.914 |
Mar 4 2008, 07:12 PM
Now this is just me but I would rather drill the head and add a nipple then try to seal them to the valve cover. My .02
sww914 |
Mar 4 2008, 07:54 PM
If my heads weren't already vented like the one in the picture, I would vent the valve covers. It's much easier to remove the valve covers than the heads. The way that I've done it before is to drill a hole in the valve cover in a similar location to the vent in the head and weld on a piece of steel tube with a 1/2"od at the same angle as the vent in the head.
If the heads are already off and they have a flat boss cast into them for the vent, I'd just drill it out, tap it, and screw in a piece of pipe. If I didn't have a tap, I'd JB weld a tube in there. Let's git her done! |
Lo-Fi Version | Time is now: 4th May 2024 - 09:45 PM |
