oil temp gauge in fuel gauge, I want one. |
slackin' at work |
Nov 12 2007, 10:34 AM
i should be working Group: Members Posts: 265 Joined: 12-October 07 From: charlottesville, va Member No.: 8,215 Region Association: MidAtlantic Region |
So my car did not come with a center console and I don't want to modify my center "box".
I was wondering if I could buy a early 911 temp gauge and simply swap out the guts of the top portion into the top of my fuel gauge. please excuse me if this seems like a silly or noob question... Im still on the learning curve. (IMG:style_emoticons/default/biggrin.gif) Search was no help. thanks in advance. (IMG:style_emoticons/default/beer3.gif) -chris |
Thack |
Nov 12 2007, 09:56 AM
Member Group: Members Posts: 283 Joined: 1-June 05 From: Houston, Tx Member No.: 4,182 |
I want one too. The kind with the numbers so I can tell how hot the oil is.
craig downs |
Nov 12 2007, 10:00 AM
Senior Member Group: Members Posts: 768 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
There is a thread just below called Gauge Clusters where someone put the oil pressure gauge from a 911 in the top of the 914 fuel gauge. So I would say yes.
ottox914 |
Nov 12 2007, 10:14 AM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
If you can dream it, Mark can do it.
http://www.914world.com/bbs2/index.php?sho...84&hl=turbo Do a search for his products in the vendor forum. A very satisfied customer. |
SLITS |
Nov 12 2007, 10:15 AM
While you can put an oil temp guage in the place of the handbrake warning light in the combination guage, you MUST have the sender that is compatible with the guage.
type47 |
Nov 12 2007, 12:49 PM
as you shop around, depending upon how close to a CW you are, you can find gauges that are silver button centers (-73 about) and non silver button centered (74-) and if you get a numbered gauge from a 911, you need to get correct sending unit as was stated above.
ClayPerrine |
Nov 13 2007, 02:35 PM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
There were gauges like this from the factory. The sixes had gauges for oil temp, and the 74 and later 4 cylinder cars had it as a option.
I have 2 of them for the 74 and later cars. Buy neither of them had numbers on the gauge. |
Aaron Cox |
Nov 13 2007, 04:25 PM
There were gauges like this from the factory. The sixes had gauges for oil temp, and the 74 and later 4 cylinder cars had it as a option. I have 2 of them for the 74 and later cars. Buy neither of them had numbers on the gauge. WRONG.... you could get it on a 73, without a center console. those gauges have the silver dot.... and a temp gauge dissimilar to the 914/6 one. Has a light for brake, oil pressure, alternator and all of them have a dummy light for sportomatic oil temp (the white plug) dont make me get a pic clay only difference us the silver button vs the later ones you have. |
type47 |
Nov 13 2007, 05:38 PM
someone posted a template with silkscreened numbers suitable to put in the oil temp gauge
SLITS |
Nov 13 2007, 06:01 PM
You imaged the narrow red band guage .... what about the wide red band guage?
type47 |
Nov 13 2007, 06:19 PM
like this?
Aaron Cox |
Nov 13 2007, 06:34 PM
bada bing
BMartin914 |
Nov 13 2007, 07:17 PM
||| Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
The complete setup (module and sender) is available from Performance Products for less than $100.
jjs3rd914 |
Nov 13 2007, 07:38 PM
Member Group: Members Posts: 124 Joined: 8-August 04 From: Sarasota, FL Member No.: 2,476 |
Is it possible to take the guts from the round temp gauge that went into the center console, and install those guts into the fuel gauge assembly. I have an extra temp gauge and a couple of the fuel gauges (with idiot light) assemblies? The arc looks similar.
Anyone ever done this? jjs3rd914 |
Rockaria |
Nov 13 2007, 07:43 PM
ZippidyDoDah... Group: Members Posts: 817 Joined: 2-May 03 From: Southwest, USA Member No.: 645 Region Association: None |
Yes!
(IMG:http://www.rockaria.com/914/images/914ngauge1.jpg) Is it possible to take the guts from the round temp gauge that went...Anyone ever done this? jjs3rd914 |
lotus_65 |
Nov 13 2007, 07:46 PM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
the arc is actually pretty far off IMHO, i looked at it when i did mine. i got a 911 gauge for like $15., gutted the two and rebuilt the one. obviously i didn't care too much about the angle of the numbers...
http://www.914world.com/bbs2/index.php?act...t&id=130672 |
jjs3rd914 |
Nov 13 2007, 07:55 PM
Thanks, we age going to investigate this. I have a center console and want to put a oil pressure (vdo) gauge in place of the temp gauge. Moving the temp gauge to the dash make it possible.
jjs3rd914 |
Lo-Fi Version | Time is now: 17th May 2024 - 03:10 PM |
