Relay panel, Hold down techniques |
Pat Garvey |
Nov 12 2007, 08:11 PM
I know that the late models had a strap of some sort to hold the relay panel in place, but what about the early 914's?
My '72 has a long screw, with a wing nut soldered to the top. I've heard that very early cars did not have this configuration & that it was simply the long screw with a simple nut attached at the top. True/false? Pat |
freezing14 |
Nov 13 2007, 07:46 AM
freezing14 Group: Members Posts: 435 Joined: 21-June 04 From: brockville , Ontario, Canada Member No.: 2,233 |
hi pat ,, I am the opposite of you ,, all the relay board I ever had all had the post in the middle of the board, with a thumb screw on top , never a wing nut
davep |
Nov 13 2007, 10:59 AM
914 Historian Group: Benefactors Posts: 5,138 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Some have the long screw with the welded wingnut.
Others have a threaded post with a knurled nut. |
JeffBowlsby |
Nov 13 2007, 04:26 PM
914 Wiring Harnesses Group: Members Posts: 8,490 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I know that the late models had a strap of some sort to hold the relay panel in place, but what about the early 914's? First I have seen this Pat. Is it in the manual or do you have a photo? The later cars do not have the post/nut (it probably leaked and led to water probklems is my assumption). But the cover stays put without any sort of strap. |
Pat Garvey |
Nov 14 2007, 08:58 PM
I know that the late models had a strap of some sort to hold the relay panel in place, but what about the early 914's? First I have seen this Pat. Is it in the manual or do you have a photo? The later cars do not have the post/nut (it probably leaked and led to water probklems is my assumption). But the cover stays put without any sort of strap. I'll post a pic on Thursday! Pat |
JeffBowlsby |
Nov 20 2007, 11:49 AM
Hi Pat (IMG:style_emoticons/default/bye1.gif)
Pat Garvey |
Nov 20 2007, 07:32 PM
Oh crap! I forgot something again, didn't I. Sorry Jeff. Been trying to find a proper box to ship a rear bumper top in for the last 10 days (no luck!) & forgot about the fastener. I have to wash the 914 tomorrow afternoon & will pull 2 parts & photo them - the screw & the thingy inside the intake. Promise! Pat |
Cap'n Krusty |
Nov 23 2007, 05:28 PM
Early cars had a stud with a knurled finger nut, late cars had no hole or hold down of any kind. Never saw a wing nut in this application. The Cap'n
Pat Garvey |
Nov 23 2007, 06:24 PM
Early cars had a stud with a knurled finger nut, late cars had no hole or hold down of any kind. Never saw a wing nut in this application. The Cap'n The Cap'n is correct, as usual. And I'm ridden with the big A, as usual! I mixed up the realy panel holddown with the air cleaner holddown - a reasonable mistake, don't you think. Sorry, trying to do too many things at the same time. Yes, the early 914's had knurled nut. Damn, wish I could get my nuts straight (well, ...you know what I mean)! Pat (IMG:style_emoticons/default/wacko.gif) |
Lo-Fi Version | Time is now: 6th May 2024 - 06:09 AM |
