COOKIE WIERDNESS, was WINNT temp internet files |
seanery |
Dec 31 2003, 09:18 PM
I'm running winxp that looks like it was based on either an early build or an upgrade from NT. My windows folder is called WINNT. I've had the PC since Nov 2002 (new). I'm having a cookie problem here and can't find them. Where are they? Where is all the temporary internet crap? It's not in the usual (to me) places.
thanks in advance. |
cnavarro |
Dec 31 2003, 09:22 PM
Cylinder Guru Group: Members Posts: 472 Joined: 30-December 02 From: Chicagoland! Member No.: 49 Region Association: None |
\documents and settings\**user name**\cookies
that's where they should be. if you have multiple users, there might be multiple directories. Charles Navarro LN Engineering http://www.LNengineering.com Aircooled Precision Performance |
Drums66 |
Dec 31 2003, 09:23 PM
I think hit Tools, then to internet options, temps & cookie settings right there!!
seanery |
thanks Charles!
seanery |
Dec 31 2003, 09:27 PM
HMMM, this webpage won't remember still. Even after I cleared all the cookies.
seanery |
Dec 31 2003, 09:34 PM
Any ideas?
I've deleted all cookies again. And rebooted and deleted again. Still, I have to login every time. I know that's not a huge deal, but the notebook works correctly, so this one should as well. (IMG:style_emoticons/default/sad.gif) |
seanery |
Dec 31 2003, 10:02 PM
this is all I have for cookies. I can delete them and the result is the same.
vortrex |
Senior Member Group: Members Posts: 1,687 Joined: 24-December 02 From: SF, CA Member No.: 4 Region Association: None |
EDIT: ignore this post.
redshift |
Jan 1 2004, 12:58 AM
Sean, I think you got hit by a marketing 'wonky' program.
Something poooped up on my computer when I was dragged away from something I clicked on from google a few weeks ago, and it destroyed cookie handling, after the computer finally restarted. (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/ohmy.gif) (IMG:style_emoticons/default/mad.gif) I protect myself (usually) by disabling ActiveX controls, I just made a boo boo, and missed something. I tried it all, then reinstalled. (IMG:style_emoticons/default/sad.gif) M |
Jan 1 2004, 01:50 AM
go to your internet settings,
control panel, internet options ... the the privacy tab, make sure your settings are LOW enough to get the cookies set/read. then, go to the security tab, click on the 4 icons and make sure each is set to "default level" ... Andy |
redshift |
Jan 1 2004, 01:59 AM
If it's the same problem I had (sounds that way) you will know, because that won't work, and if you ...
Hey wait seanery dood... do you have your XP setup to have restore points enabled? If you do, go back a restore point at a time, until it works. M |
seanery |
Jan 1 2004, 07:12 AM
i don't restore, i'd have to think ahead to do that.
seanery |
Jan 1 2004, 07:40 AM
hmm, well, I've reset all security to default levels and even tweeked 'em lower just to check it out and still no go.
This computer has Spybot Search & Destroy and BHO Cop, Norton Anti-Virus. I don't think its anything like that, maybe I'm wrong. |
Brad Roberts |
Jan 1 2004, 03:23 PM
I havent had any problems. I'm running almost exactly what you are running (Spybot/Norton)
When was the last time you pulled any updates from MickeySoft ?? B |
seanery |
Jan 1 2004, 05:20 PM
probably a long time ago. I've been using the notebook and hanging out upstairs, but I've done a lot of work down in the basement and I don't wanna go upstairs (IMG:style_emoticons/default/laugh.gif) so I wanna get the desktop sussed out.
seanery |
Jan 1 2004, 05:53 PM
XP is current and still not right (IMG:style_emoticons/default/mad.gif)
kafermeister |
Jan 2 2004, 07:09 AM
Senior Member Group: Members Posts: 778 Joined: 20-January 03 From: Cincinnati/Northern KY Member No.: 174 |
Go here...
tools>internet options>settings>view objects ...and look at the list of "downloaded program files". Start going through this stuff and look for things that you know don't belong. If you right-click>properties on the items, you can check the CodeBase URL to see if it's legitimate. Worst case here is that you delete everything and the proper stuff re-installs itself when necessary. Also, go through ControlPanel>Add-Remove-Programs and look for stuff that doesn't have a size listed. It may be suspect. There will definately be stuff witout a size listed that is legitimate so you'll have to strain the nogin to determine what should be deleted and what shouldn't. In addition to what I have listed above, I've pasted text below from a web page that has helped me alot. The spaces and carrage returns got screwed up when I pasted it but they weren't well defined to begin with. I deleted everything that I found in the text below and it really helped my system. Rick Additional folders found under C:\Program Files Autoupdate ClipGenie DownloadWare Flt Grokster Lycos MyWay Pop RVP scbar Srng ToPicks webHancer Additional entries found in "Add/Remove Programs": AM Server Batch Assistant Clip Genie Data Compiler Grokster Grokster Ads Support Indexing Function Lycos Side Search MyWay Speed bar Pop RVP ToPicks SBM OS Search OS ShopAtHome Select Agent TP HTTP URL.IE APP Win32 BI Application WebHancer Customer Corporation Additional entries under "Startup" tab of MSConfig: ASTART POP Autoupdater ToPicks Starter DownloadWare WebHancer Agent RVP SAHAgent srng SearchEnhancement CMESys UpdateGrokster GStartup |
MoronThrottle |
Jan 2 2004, 08:05 AM
Unregistered |
OK, I've done all those things. I'm trying a new account to see if that fixes, or changes anything. (IMG:style_emoticons/default/sad.gif)
kafermeister |
Jan 2 2004, 08:08 AM
It *still* says you're "logged in as:guest" when you open a new window?
MoronThrottle |
Jan 2 2004, 08:09 AM
Unregistered |
I'm not logged in at all.
I have to login everytime I open IE. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:31 PM |
