914 Side seals on targa bar $12, Repair kit |
Mikey914 |
Nov 17 2007, 06:11 PM
The rubber man Group: Members Posts: 12,670 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I've had allot of feedback on these, and have changed the concept slightly with these. This is more of a "repair kit". Most buyers have been taking the stock ends and gluing the old ends to the new seals. I'm also including 8 low profile screws to help with the installation. Any gaps that need to be filled can be caulked with polyurethane caulking.
And, of course you can cut and glue the ends if you want. This comes with 8 low profile screws to help the installation. You can still use these by cutting and filling if you do not have the ends. An excellent alternative to complete new seals, most of the time the ends are in the best shape. Attached image(s) |
Mikey914 |
Nov 17 2007, 11:02 PM
Mine will have the hole running up the center, the end will be sealed and mitered so the corner where it cones together will keep out water. I have several choices as far as the hardness of the rubber. I'm thinking about keeping close to the factory part, maybe a little softer.
Lo-Fi Version | Time is now: 20th May 2024 - 11:50 AM |
