Nissan V6 Twin Turbo |
outpost962 |
Nov 20 2007, 12:06 PM
Newbie Group: Members Posts: 7 Joined: 15-November 07 From: southern New Jersey Member No.: 8,343 |
Hi fellows,
Newbie here (IMG:style_emoticons/default/smile.gif) This is a great site. Congrats to all those who maintain and contribute. Has anyone here installed or done the measurement/fit calculations on installing the Nissan VG30DETT Twin Turbo motor in the 914? I've done some preliminary budget work. Now I'm down to the engineering. Any and all help will be appreciated. |
BMXerror |
Nov 20 2007, 12:13 PM
Senior Member Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
I can't offer any engineering advice, but I will say kudos for trying something different. I was thinking of doing the same sort of thing with a Mitsubishi twin turbo V6. Don't let yourself get shouted down by the 'put a Chevy' or 'put a Suby' or 'keep it Porsche' guys. I'm anxious to see how this turns out.
Mark D. |
TravisNeff |
Nov 20 2007, 12:29 PM
Not that I have heard, but there was someone who put a nissan 300ZX v6 engine in their 914. You can get the adapter for the transmission at kennedyeng.com
outpost962 |
Nov 20 2007, 12:47 PM
Not that I have heard, but there was someone who put a nissan 300ZX v6 engine in their 914. You can get the adapter for the transmission at kennedyeng.com I'm in touch with Kenndyeng. Would'nt do a project with them. They're great folks to talk with as well. Got nice info from them. thanx (IMG:style_emoticons/default/smile.gif) |
outpost962 |
Nov 20 2007, 01:33 PM
I can't offer any engineering advice, but I will say kudos for trying something different. I was thinking of doing the same sort of thing with a Mitsubishi twin turbo V6. Don't let yourself get shouted down by the 'put a Chevy' or 'put a Suby' or 'keep it Porsche' guys. I'm anxious to see how this turns out. Mark D. Thanks Mark The Nissan ttV6 is a little lighter and less expensive than than the V-8. A healthy Nissan ttV6 can deliver 400+hp with mild tuning. If this works out I'll give a blow by blow build up page Thanx. |
dlo914 |
Nov 20 2007, 02:07 PM
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
Here's where i picked up my JDM Toyota 4AGE 16v motor for $395 out the door w/ 180lbs psi/cylinder. http://enginelandusa.com/nissan.htm
neo914-6 |
Nov 20 2007, 03:12 PM
Hi fellows, Newbie here (IMG:style_emoticons/default/smile.gif) This is a great site. Congrats to all those who maintain and contribute. Has anyone here installed or done the measurement/fit calculations on installing the Nissan VG30DETT Twin Turbo motor in the 914? I've done some preliminary budget work. Now I'm down to the engineering. Any and all help will be appreciated. Look at my non-OEM conversion link, one member installed a non-turbo V6. I've heard of another but the owner had sold it. Search "nissan" on this site. Be prepared to pad your budget, these are always more time and $ consuming than planned. I should know... |
Wes V |
Nov 20 2007, 03:41 PM
Member Group: Members Posts: 482 Joined: 11-October 07 From: Los angeles Member No.: 8,211 |
You have to think about more than just the engine!!
From what I've been able to figure out, a 901 transmission will not hold up to a twin turbo V6. If you step up to a 915 transmission, you will have to "flip" the ring gear and then buy one of the Wevo shift kits. The Wevo kit is $2000 alone. Even then, a lot of people state that the shifting isn't that good. I personally like what Neo914-6 is doing. He is using an Audi twin turbo V6 and a porsche boxster transmission (they bolt together without an adapter). The boxster transmission is the same as the Audi "012" transmission used in the Passat (read Audi as not costing as much as Porsche). As with all swaps, there are a lot of things to "fiddle" with. Using the boxster transmission means that you have to convert to a cable shifter. You have also got to come up with a solution for the axles (and I think Neo is just now getting that figured out). Wes V |
orange914 |
Nov 20 2007, 03:56 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
You have to think about more than just the engine!! From what I've been able to figure out, a 901 transmission will not hold up to a twin turbo V6. Wes V why not use the engine AND trans? you probably wouldnt be in for anymore work than adapting up a tranny you need to upgrade anyway. my son has a 95 maxima 5sp w/ 3.0 dual overhead (i believe same engine family). i've always thought that would be a good doner... 200 stock/reliable fuel injected h.p. that would probably get 40 m.p.g. (right now gets 30 freeway mpg in that heavy boat.) mike (IMG:style_emoticons/default/welcome.png) |
Wes V |
Nov 20 2007, 04:39 PM
The reason for having to change the transmission when using the Audi ttV6 is that ALL of them came with four wheel drive! It's that simple.
Wes |
orange914 |
Nov 20 2007, 05:10 PM
The reason for having to change the transmission when using the Audi ttV6 is that ALL of them came with four wheel drive! It's that simple. Wes i was refering to the nissan twin turbo v-6 in the first post. although anything is possible with enough work (IMG:style_emoticons/default/beerchug.gif) |
Wes V |
Nov 21 2007, 08:44 AM
Orange914;
For the sake of discussion (in other words, I don't want to start a heated arguement); What matching engine and transmission are you talking about? If we are talking about a Nissan V6 then there are pretty much just two configurations. One is with the engine mounted "transverse" in the chassis and is front wheel drive. If you wanted to use this combination in a 914 (in the rear), then the engine would still sit transverse in the chassis. I don't think any of the Nissan turbo motors came this way. In the 350Z, the engine mounts longtudinally (which is good), but the attached transmission is for "front engine / rear wheel drive". You couldn't mount this configuration in the rear of a 914. There are similar (but slightly different) issues with the Audi TTV6, and that's why you need to mix and match engine / transmission combinations. Wes Vann |
Scott Carlberg |
Nov 21 2007, 12:06 PM
Porsche MOTORSPORTS Group: Members Posts: 1,595 Joined: 17-April 03 From: Modesto, Ca Member No.: 580 |
Years ago (before this site existed) Steve Malm down in SoCal put a nissan v6 in his 914, though I think it was from a 280z, I *think*.
Chris in Las Vegas put a 3.0 v6 from a nissan maxima in his 914. You should stay with a German powerplant though! (IMG:style_emoticons/default/poke.gif) |
jaminM3 |
Nov 21 2007, 02:14 PM
Member Group: Members Posts: 418 Joined: 23-March 07 From: SLC, UT Member No.: 7,619 Region Association: Intermountain Region |
Years ago (before this site existed) Steve Malm down in SoCal put a nissan v6 in his 914, though I think it was from a 280z, I *think*. Isn't a 280Z a straight six? (IMG:style_emoticons/default/confused24.gif) |
dlo914 |
Nov 21 2007, 02:17 PM
Years ago (before this site existed) Steve Malm down in SoCal put a nissan v6 in his 914, though I think it was from a 280z, I *think*. Isn't a 280Z a straight six? (IMG:style_emoticons/default/confused24.gif) Yup! But yeah do whatever powerplant ya want, it's your car! The more unique the better i always say! Hell my next 914 will definitely not be powered by a Type4, im gonna go w/ a Subaru EJ20T (IMG:style_emoticons/default/biggrin.gif) |
orange914 |
Nov 21 2007, 08:39 PM
Orange914; For the sake of discussion (in other words, I don't want to start a heated arguement); What matching engine and transmission are you talking about? Wes Vann i was thinkin' the transverse dual overheat v-6 5 speed, a bit different but i think it would be kuool! mike |
XrayMed |
Nov 22 2007, 11:13 AM
Newbie Group: Members Posts: 17 Joined: 1-November 07 From: Beaumont, Texas Member No.: 8,289 |
I personally like to stay all porsche. But like the other guy said its your 914 you can do what ever you want. After all we are customizing them right.
My thoughts where to stay all porsche, much like chappy did with his. 911 twin turbo engine, 911 front suspention with 911 5 lug all the way around. That way its all still porsche but pretty heavly modifed. Those where my plans for my 914. From what I have read and researched doing it this way there is alot more direct bolt up (with the exception of twin turbo and the intercooler) and that means less time in the rebuild stage and more fun time on the road driving it. The more you deviate from origninal (ie other parts not inteneded for 914) then the more mods and engineering to make it work right. I personally don't want to be engineering for months to get it to work right. This is just something you might want to think about. Allot of the guys on here are doing the 911 conversion and then there is the V8 conversion these have all been tested and done and alot of parts to help to get you up and running rather fast. Just some food for thought. No matter what you do. You have got to take pictures and show us. LOL! |
outpost962 |
Nov 26 2007, 08:46 PM
Thanks to everyone for advice ,info, and food for thought.
As with any project plenty of all of the above are needed before and during the build. Special thanks to Neo 914-6 for the photo's in your AUDI/914 build-up, they will be a great help in the future. I'm going to build a small shop and begin collecting the major parts and tools I need to begin in late spring early summer. Any additional info and pictures will be greatly appreciated. I will photograph every step as i go along. THANKS WHATS THE BEST YEAR 914 FOR THIS BUILD? |
orange914 |
Nov 26 2007, 09:04 PM
(IMG:style_emoticons/default/birthday3.gif)
Thanks to everyone for advice ,info, and food for thought. WHATS THE BEST YEAR 914 FOR THIS BUILD? i dont know about the smog check requirements in your state but here in ca. the years smog check free (at least 4 now) are 75 and down. so i'd say 73, 74, and 75. 73 and up have the better shifting trans linkage (side shifter). but east coast and rust issues, i'd go w/ the most rust free one you can find. do a search on "hell hole", "longs" and rust in general or post asking us 4 pictures/info. on rust areas (IMG:style_emoticons/default/welcome.png) mike |
alpha434 |
Nov 26 2007, 10:18 PM
My member number is no coincidence. Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains |
Isn't the 350z a rear transmission car?
You could still use a rear configuration transmission. Easy. Just run a coupler instead of a long torque tube. 944s use a rear trans too. Same dealie. |
Lo-Fi Version | Time is now: 15th May 2024 - 10:28 PM |
