I saw an ad of a 914, With Side Draft Webers |
JoeSharp |
Nov 21 2007, 09:33 AM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
I caught a link to an add for a car that was for sale. It had a really nice set-up on the carbs. The linkage is what I'm interested in. I need it to show how the linkage should work. I'd like to use it for the Carb Tech session we are having on the 1st of December.
Anybody see that add and can remember where it is? |
GaroldShaffer |
Nov 21 2007, 09:52 AM
I think you are talking about my race car engine? Here is one picture. I can take more pictures, jst tell me what you want to see. Attached image(s) |
JoeSharp |
Nov 21 2007, 10:25 AM
Way Kool Garold. If you can, a pic from the end of the throttle shaft lever.
Very well thought out linkage. |
maf914 |
Nov 21 2007, 12:29 PM
Gerold, very interesting.
How were the manifolds made? They look like a combination of stock FI runners at the heads and cast aluminum weber manifolds at the carb bases. How does it run? |
Katmanken |
Nov 21 2007, 07:52 PM
Wonder what the intake pulses from the opposing carbs and the common plenum do? Better or worse for pulse tuning?
More pics of the plenum and carbs from different views. Where is the intake for the plenum? Ken |
GaroldShaffer |
Nov 26 2007, 03:44 PM
Joe, here are some more pictures. Hope they help
QUOTE How were the manifolds made? They look like a combination of stock FI runners at the heads and cast aluminum weber manifolds at the carb bases. How does it run? Honestly I don't know. (IMG:style_emoticons/default/smile.gif) It was out of the car when I got it. I will know by spring time I hope. Attached image(s) |
GaroldShaffer |
Nov 26 2007, 03:45 PM
KaptKaos |
Nov 26 2007, 04:06 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
Wow!
Root_Werks |
Nov 26 2007, 04:09 PM
Village Idiot Group: Members Posts: 8,319 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
That looks sweet!
jd74914 |
Nov 26 2007, 07:15 PM
Wonder what the intake pulses from the opposing carbs and the common plenum do? Better or worse for pulse tuning? More pics of the plenum and carbs from different views. Where is the intake for the plenum? Ken I think that the pulses would interfere with each other. I would also be worried about gas condensation in cold weather. For a race engine those runners are pretty long and have a huge bend in them; usually people want the lest restrictive path into the head. It is a really interesting setup though, I'm just confused as to why it was done? |
Aaron Cox |
Nov 26 2007, 09:10 PM
Wonder what the intake pulses from the opposing carbs and the common plenum do? Better or worse for pulse tuning? More pics of the plenum and carbs from different views. Where is the intake for the plenum? Ken I think that the pulses would interfere with each other. I would also be worried about gas condensation in cold weather. For a race engine those runners are pretty long and have a huge bend in them; usually people want the lest restrictive path into the head. It is a really interesting setup though, I'm just confused as to why it was done? :word: (IMG:style_emoticons/default/agree.gif) seems like you just introduced a 'U turn" into the head. remember the factory FI didnt have fuel going through the runner.... just aimed the injector at the back of the intake valve. This seems like it would duplicate the problems of a single carb/long runner application... neat idea, but why? |
GaroldShaffer |
Nov 26 2007, 09:16 PM
I have no idea why they / he did it. I can't ask him since he has passed away, but from what I was told by some of his friends it worked great. Only time will tell. I plan to get in to it in Jan '08
JoeSharp |
Nov 26 2007, 09:37 PM
Yeah, it seems to me that the intake is rather long and that the air plenum could have had more room. But I liked the solution to the carb linkage.
At half throttle all the forces are tangent to arc of the levers on the linkage. Thanks Garold. |
Aaron Cox |
Nov 26 2007, 09:40 PM
Yeah, it seems to me that the intake is rather long and that the air plenum could have had more room. But I liked the solution to the carb linkage. At half throttle all the forces are tangent to arc of the levers on the linkage. Thanks Garold. only at that one spot though. I think every hex bar linkage hits that 'tangent to the arc' spot. I think one advantage of the shown setup, is it has longer link arms to the carb shafts... giving you a bit more 'resolution' of throttle opening |
KaptKaos |
Nov 26 2007, 09:54 PM
How would having the intake so close to the case affect the temperature of the air going in?
McMark |
Nov 26 2007, 10:59 PM
That is so cool. I've always thought about the side flow carbs. Nice to see someone tried it.
rick 918-S |
Nov 27 2007, 12:18 AM
Hey nice rack! -Celette Group: Members Posts: 20,458 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
That is so cool. I've always thought about the side flow carbs. Nice to see someone tried it. (IMG:style_emoticons/default/agree.gif) It's like the hemi cross ram, high RPM cruisin is where it lived and breathed. I wouldn't really care if it worked, it looks cool! (IMG:style_emoticons/default/aktion035.gif) |
sixnotfour |
Nov 27 2007, 01:08 AM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
prob. not good for a cold morning.
Lo-Fi Version | Time is now: 16th May 2024 - 11:03 AM |
