replacing suspension bushings with Brass, Am I wasting my time? |
Bill Smith |
Nov 21 2007, 09:20 PM
Member Group: Members Posts: 169 Joined: 2-May 06 From: Keyser, WV Member No.: 5,964 |
My dad is a machinist - we were thinking of replacing the front and rear bushings with brass and incorporating grease fittings. We are using brass 660 compound.
We use the car for autocross and DE. Need to be faster that a yellow 4 cyl with a Jake ruby engine, last year I tried throwing my crank pulley at him in a DE, but it didnt even slow him down. I was gong to make them a light press fit and also use JB weld to fill in the front supports that arent round. Am I wasting my time? |
Twystd1 |
Nov 21 2007, 11:15 PM
Why not Delrin???
More lubricity. Or you can make a needle bearing setup ALA Mueller. Clayton |
ConeDodger |
Nov 22 2007, 10:24 AM
Apex killer! Group: Members Posts: 23,576 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
You are reinventing the wheel. Delrin, poly, needle, elephant bushings are all in existance and require only a check and an install. I would think with brass you would want to upgrade your dental insurance at open enrollment too...
Nov 23 2007, 02:32 PM
Resident German Group: Admin Posts: 41,618 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
i hear the needle bearings will be available again soon ... (IMG:style_emoticons/default/bye1.gif) Andy |
Joe Ricard |
Nov 24 2007, 06:46 PM
I made mine out of steel for the rear on my car. The poly bushings lasted 1 year 15,000 miles.
OMG it changed the entire feel of the car. there is no more wallowing as the suspension takes a set and then the car begins to turn. I pressed in frozen bushings into heated trailing arms. I machined the steel pivot bar enough to make it round and provide .002 oil clearance. When I lift the rear of the car the wheel slowly falls to the ground under strict control of the shock. IT'S LIKE BUTTER. I also put grease fittings in each bushing. |
byndbad914 |
Nov 26 2007, 08:18 PM
shoehorn and some butter - it fits Group: Members Posts: 1,547 Joined: 23-January 06 From: Broomfield, CO Member No.: 5,463 Region Association: None |
Bill - I am not completely sold on using brass, I would think it would want to "wallow" out under heavy load and rotation. I was thinking steel and see Joe has BTDT, so I go with Joe's recommendation. I ended up not messing with it when I went tube chassis and 5-link, but I was going to try and find a bearing I could simply press in there from McMaster-Carr or something similar... maybe you could reference some roller bearing info and find one you could make work. Then if the inner pivot is the wrong size just machine your own.
McMark |
Nov 26 2007, 11:33 PM
The roller bearings will be available again shortly... (IMG:style_emoticons/default/cool.gif)
(IMG:http://www.paintandmetal.com/images/exploded.gif) |
Joe Ricard |
Nov 27 2007, 06:01 AM
With machining and material I was right at 100 bucks.
Lifted the car on Sunday to fuss around with something. I am just in awe of how smooth the wheel falls to earth. |
Lo-Fi Version | Time is now: 5th May 2024 - 06:32 AM |
