Subaru Ej25 NA Conversion Complete!, subaru Ej25 Conversion completed |
budman5201 |
Nov 22 2007, 01:26 AM
Senior Member Group: Members Posts: 595 Joined: 1-April 07 From: tempe, az Member No.: 7,635 |
Here it is finally done!! One 1998 Subaru Ej25 Naturatally aspirated($1300) in my 914. Stock Trans mounts. Stock shift bar. Stock engine front bar location mounts.(utilizing Small Car Performance Mounts for the Vanagon)($120) Kenedy Adaptor plate with Stage 2 clutch.($500) New head gaskets, Fresh machined heads (due to head gasket leak from used engine, now perfect!) Fits perfect, idles nice, Link ECU Programmable Computer Stand Alone G3 Version($1200). Renegade Radiator($995) up front (works very nice). For only 175hp this baby is fast! & much needed these days...32 mpg highway!! (I have two programs, one for 89 unleaded(economy) and one for 92-93 premium(performance 24 mpg))
budman5201 |
Nov 22 2007, 01:28 AM
engine compartment (that one misc hose is not there anymore, it was the air recirculation plasic hose that runs to the front of the car)
budman5201 |
Nov 22 2007, 01:29 AM
actual WRX expansion tank
budman5201 |
Nov 22 2007, 01:32 AM
Patrick motorsports Exhaust Cans with Supertrap Adjustable Endcaps to keeps the neighbors happy (sound is lower)
budman5201 |
Nov 22 2007, 01:34 AM
underneath from drivers side rear bumper
budman5201 |
Nov 22 2007, 01:51 AM
Custom EASY to Make Front Engine Bar that bolts to Small Car Performance mounts. (this is when i was pulling the heads off to have them resurfaced for new head gaskets. and new timing belt of course.
This is a nice clean picture of how to make the bar. ( Oh one bolt is missing on top right of center (didnt replace it yet) I ended up modifying the Small Car Performance mount on the Drivers side. I flipped the mounting bolt location to the inside (not pictured in this picture) so i could put a brand new AMERICAN version of the water pump on. It exited out the front which is perfect, but the bolts were in the way, so once flipped. It worked perfectly (IMG:style_emoticons/default/smile.gif) Attached image(s) |
village idiot |
Nov 22 2007, 02:49 AM
Member Group: Members Posts: 65 Joined: 15-September 07 From: Honolulu Member No.: 8,120 Region Association: None |
Nice! I've been thinking about swaps lately as well and the Subie engines are high on the list.
roadster fan |
Nov 22 2007, 03:16 AM
Project Frankenstein !!!!!!!! Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California |
type47 |
Nov 22 2007, 06:46 AM
truely impressive! what are you doing about heat and defrost?
your project will surely lead others to do the similar conversion... performance and economy. |
JeffBowlsby |
Nov 22 2007, 09:44 AM
914 Wiring Harnesses Group: Members Posts: 8,501 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Nice and clean install and economical! What was your thinking about not rotating the intake manifold 18 degrees?
siverson |
Nov 22 2007, 10:03 AM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
Nice, any idea how much the weight changed? More or less?
-Steve |
MartyYeoman |
Nov 22 2007, 12:22 PM
Senior Member Group: Members Posts: 1,518 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
Sweet!!!!!!
Dr. Roger |
Nov 22 2007, 02:17 PM
i always liked the look of those super trapps....
good work. economical without sacrafice of reliability. (IMG:style_emoticons/default/beerchug.gif) Attached image(s) |
jonferns |
Nov 22 2007, 02:31 PM
budman5201 |
Nov 22 2007, 06:22 PM
the reason for the no 180 degree rotation on manifold is that AC is eventually going in and if i rotated it the compressor wont fit. Videos soon! i drove it to thanksgiving about 40 miles from my house....ran at 172 degrees whole way 80 mph.
weight not known yet. I'll get that done when i get it dynoed next week. it is just wideband o2 sensor tuned. |
TonyAKAVW |
Nov 23 2007, 04:10 PM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
So your exhaust sertup is individual mufflers for each side? What do you do for your O2 sensor?
budman5201 |
Nov 24 2007, 02:25 AM
budman5201 |
Mar 16 2008, 01:12 PM
I am now offering this EJ25 NON-turbo conversion as a complete kit for $6500. This includes the engine complete setup with intake, engine cradle, engine bar, stage 2 stock clutch, pressure plate,transmission adaptor plate for engineto bolt to the stock transmission, custom flywheel to accept stock stage 2 clutch , Custom modified intake throttle body, Custom shortened oil pan, Link Computer (pre- programmed for the ej25 so it will start right up. Already wired to the engine harness. (plug in adaptor))
My system bolts right in, NO modifications neccesary to the body whatsoever. Fits in the engine compartment with no cutting of anything. Mounts lower than the Renegade system, but once again. NON-turbo ONLY. PM me if interested. Attached image(s) |
budman5201 |
Mar 16 2008, 01:15 PM
more pics
yenningComity |
Mar 16 2008, 01:37 PM
Newbie Group: Members Posts: 38 Joined: 27-August 07 From: Carmel Indiana Member No.: 8,047 Region Association: Upper MidWest |
Nice as for a kit, if you could manage to do put the radiator in the engine bay and save losing the front truck I would be interested. It would be rather nice to have a bolt in engine so that if you did want to go back it wouldn't take much more than an engine drop.
Lo-Fi Version | Time is now: 12th May 2024 - 01:51 PM |
