Voltage Regulator, wiring color code? |
smooth_eddy |
Nov 24 2007, 04:18 PM
Senior Member Group: Members Posts: 535 Joined: 13-November 04 From: Seattle Member No.: 3,102 |
I just bought a new Bosch voltage regulator. The old one is not a OEM and has the wiring harness molded into the case. So I need to cut the wires and use spade crimp connectors on the new Bosch. So the problem is I have a Red, Black and Green wires on the harness. The terminals on the regulator are labeled: DF, D-and D+. Is it a straight through connection? Whould I be better off buying a new harness with a double ended plug connector?
Thanks, Eddy |
ejm |
Nov 24 2007, 05:17 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,691 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
This help?
smooth_eddy |
Nov 24 2007, 05:27 PM
Hmmm....
Well assuming the brown wire in the diagram is my black? wire, then this is a great help. Thanks Ed......... (IMG:style_emoticons/default/aktion035.gif) |
dr914@autoatlanta.com |
Nov 24 2007, 06:35 PM
914 Guru Group: Members Posts: 7,857 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I just bought a new Bosch voltage regulator. The old one is not a OEM and has the wiring harness molded into the case. So I need to cut the wires and use spade crimp connectors on the new Bosch. So the problem is I have a Red, Black and Green wires on the harness. The terminals on the regulator are labeled: DF, D-and D+. Is it a straight through connection? Whould I be better off buying a new harness with a double ended plug connector? Thanks, Eddy Eddy the voltage regulator should plug directly into the relay board. That is the only way to do it not worth all of the trouble to try to splice wires! |
SGB |
Nov 25 2007, 12:28 AM
I agree with the Doc. I think you may have an incorrect replacement. Show us a pic. The bus regulator will sorta work. That may be what you have now.
smooth_eddy |
Nov 25 2007, 10:01 PM
I bought the part from Bow Wow, a VW part store. They told me it's the correct one. I do know the regulator in the car is not a factory original OEM. This one is part # 0 192 062 007. I think I will return it because I am not crazy about adding the stake on terminals when there should be a molded plug, which is fool proof. I will try to order the correct one on Monday.
Eddy |
smooth_eddy |
Nov 26 2007, 02:39 PM
Well made a few calls today and found out the harness is about $175, used. Way too much for 2 plugs and only 3 wires that is about 3 inches long. Does anyone know if I have the correct regulator? See part number above.
Thanks |
Lo-Fi Version | Time is now: 16th May 2024 - 02:13 AM |
