I just bought a new Bosch voltage regulator. The old one is not a OEM and has the wiring harness molded into the case. So I need to cut the wires and use spade crimp connectors on the new Bosch. So the problem is I have a Red, Black and Green wires on the harness. The terminals on the regulator are labeled: DF, D-and D+. Is it a straight through connection? Whould I be better off buying a new harness with a double ended plug connector?
Thanks, Eddy
